Author Topic: Which direction does spline coupling go  (Read 2652 times)
Offline gearman
« on: August 22, 2017, 09:06:27 AM »
On a 77 convert the drive u joint coupling has a relief on ONE  end but I don't know which end goes  to the final drive. Thanks
Re: Which direction does spline coupling go
« Reply #1 on: August 22, 2017, 11:24:52 AM »
I put it against the circlip, but that's just me.
Offline gearman
« Reply #2 on: August 23, 2017, 08:44:37 AM »
I called Curtis Harper and he said it was tapered and the relief side went to the final drive side. I checked for slop and the one direction wiggled more than the way Curtis said. Thank You. It is together now.
« Reply #3 on: August 23, 2017, 01:21:03 PM »
Tapered?  What is tapered?
Offline normzone
« Reply #4 on: August 23, 2017, 06:01:59 PM »
" Which direction does the spline coupling go ? "
In my experience they're pretty consistent about going the same direction as the rest of the bike.
If it deviates by very much you'll know right away.
 :evil:
Offline mtiberio
    • TiberioRacing
« Reply #5 on: August 24, 2017, 09:06:38 AM »
Convert rear drives and drive shafts do not have circlips.
Land Speed Records w/Guzzzi:
SCTA M-PG 1000 141.6 MPH
LTA M-PF 1000 137.3 MPH
ECTA M-PG 1000 118.6 MPH
Offline gearman
« Reply #6 on: August 26, 2017, 11:57:27 AM »
I was quoting Curtis. The coupling went on the male splines with wiggle in it one way and when I turned it end for end it went on with no wiggle. That was with the relief  toward the final drive.There is a rubber spacer and then a snap ring on the tranny shaft.So everybody is right. :grin:
« Reply #7 on: August 26, 2017, 02:22:58 PM »
Thanks for clarifying that.
The coupling should not show any more slop in either direction.  In other words, it's not tapered.  If it was, it would ride up and bind on the male splines, and you would lose your plunge.  Gotta have that plunge.  Look at the female splines carefully.  Are they nice and square, or are they "tented"/look like triangles with flat tops?  Is there a ridge going around the inside center of the coupler?  These an taper are classic signs of a worn coupler.
