Author Topic: K&n air filter for Convert  (Read 5844 times)
Offline gearman
« on: August 26, 2017, 12:05:58 PM »
Any body here have  ro642 or mg 2640 filters. The bike had ro642 s and they are all  distorted from being jammed in.The mg2640 looks interesting. It is a 2 into 1 design. They say you can leave the v. stacks.Thanks
Offline antmanbee
Re: K&n air filter for Convert
« Reply #1 on: August 26, 2017, 01:05:18 PM »
I use this setup. I did it on my old Convert and T3 40 years ago and I do it the same way on my Calvin and Jackal.
There is a spring on the inside that I just slip over the velocity stacks and then clamp gently. This is much less expensive than K&Ns.
It is a UNI U-802. You need to carefully cut out the other end of the sock so both are open and buy another hose clamp to make it work. Oil lightly.
Offline chuck peterson
« Reply #2 on: August 26, 2017, 01:15:12 PM »
Velocity stacks are a touch too large. Solution is to turn down the outside to make a snug fit, and it saves the Venturi on the inside of the stack.
150k on Verts
750 Nevada
400f
R5 Yammie
BV250
Offline Idontwantapickle
« Reply #3 on: August 26, 2017, 01:58:35 PM »
I have one, I'll go put my hands on it. Never used.
Hunter
Sir James Paul McCartney
AMA Charter Life Member
72 Eldo
84 BMW R100RS
« Reply #4 on: August 26, 2017, 02:52:09 PM »
The R0642 can be used with the "stacks", I've done it a bunch of times. Just warm the filter, lube it up with some silicone spray and it'll slide up over the unmodifed stack. When it's time to clean them, I don't remove the filter from the stack, I simply unscrew the stack from the carb.
I find the MG2640 filter to be a bit of a PITA to get on and back off for cleaning, even if I warm and lube it.
On my Convert, I used the original "stacks" and the RU2450 K&Ns. Fit nicely and are relatively easy to remove for cleaning.
