Author Topic: norge fork level  (Read 2143 times)
Offline Rich Dwayne
norge fork level
« on: August 26, 2017, 02:13:47 PM »
400 ml is to get you to 140 mm from top of tube less spring and pre
load pipe? I am at 240 mm with leg compressed
Offline Idontwantapickle
Re: norge fork level
« Reply #1 on: August 26, 2017, 04:11:36 PM »
Yes,  that is what the manual states and mine was pretty close to that quantity. Are you positive the tube is fully inserted when measuring?  If you had disassembled the leg are you sure it is back together correctly and are you positive that you measured the fluid correctly? Not to throw shade on your talents,  just asking.
A slight difference in the tube insertion makes a pretty big volume change for the purposes of this measurement.
Hunter
Sir James Paul McCartney
AMA Charter Life Member
72 Eldo
84 BMW R100RS
Offline toolittletime
    • mysportgear.com
« Reply #2 on: August 26, 2017, 05:25:36 PM »
Isn't it 540 ml......18.2 oz to get it 110mm from the top (4.33 inches)  without the spring or preload pipe?
Tim
X-MSF Instructor
MGNOC 22710
12 Norge
2002 Cali EV
74 Eldorado
« Reply #3 on: August 27, 2017, 04:13:56 AM »
Is it acceptable to just dump the old stuff out and after washing, just up end the requisite volume in. I've changed mine 6 times in 130,000 and no problems at all.
« Reply #4 on: August 27, 2017, 05:32:38 PM »
I'm sure close is close enough as your experience shows. It seems that what Guzzi is after is a particular volume of air in the unit. That would affect rate under heavy compression. Just a thought.
Hunter
72 Eldo
84 BMW R100RS
Offline Rich Dwayne
« Reply #5 on: August 27, 2017, 11:21:53 PM »
Thanks for the input, I went with my gut and history of guzzi double speak. I dropped that black tube in and the level came to 140mm, bolted it all together, went for a 100 mile shake down, no leaks, shakes all seems well. I torn to down to replace seals and dust caps. :boozing:
« Reply #6 on: August 28, 2017, 02:36:23 PM »
Hi mate, nice to hear from you.
