Author Topic: Metal/rubber sealing washers?  (Read 6599 times)
« on: August 27, 2017, 07:39:45 PM »
I'm looking to buy a quantity of sealing washers for various banjo-type fittings.  I see this kind of washer that Honda outboards have used for years on their outboard engine drain plugs.  It has a metal outer ring with a soft "rubber-ish" inner ring.  I suspect the soft material isn't actual rubber.  My question is:  Has anyone been using this type of washer to seal oil and brake banjos, and what has been your experience?
Offline Matteo
  • Alaska Guzzi's on Facebook
Re: Metal/rubber sealing washers?
« Reply #1 on: August 27, 2017, 07:53:15 PM »
Dave, I've been using those for a long time on my oil sump drain plugs, no leaks for years. Still using regular crush washers for my brake lines.
Offline dxhall
« Reply #2 on: August 27, 2017, 07:56:06 PM »
I think I first saw that kind of washer in the Earl's catalog years ago.  They work well and, unlike crush washers, they can be reused.  My 2003 V11 Sport has them on the oil lines.  The 1997 Centauro has the simple crush washers.  We used the Earl's washers on the race cars all the time.
Offline dsrdave
« Reply #3 on: August 27, 2017, 08:11:00 PM »
I don't like oil leaks, I use them all the time on my bikes.  Commonly referred to as a stat-o-seal.  Avail. From McMaster carr.
Offline gearman
« Reply #4 on: August 27, 2017, 08:16:53 PM »
 :1:
Offline guzziownr
« Reply #5 on: August 27, 2017, 08:18:52 PM »
I got a pair of these with my made-in-china brake line pressure switch.  I put them on and crossed my fingers.  One year in and no leaks.
YMMV  DW
Moto
« Reply #6 on: August 27, 2017, 09:04:46 PM »
I think you're referring to the type of washer (steel/rubber) that has been standard OEM-issue since, I understand, 2001 or so for Guzzi drain plugs:
http://www.mgcycle.com/index.php?main_page=product_info&cPath=34&products_id=52
If so, yes, they work well.
Moto
« Last Edit: August 27, 2017, 09:05:23 PM by Moto »
« Reply #7 on: August 27, 2017, 09:09:41 PM »
https://www.mcmaster.com/#93786A175 . Same catalog page has the other sizes.
« Reply #8 on: August 27, 2017, 09:45:22 PM »
Charlie, the washers I've been looking at are flat with a rubber insert as opposed to these "folded" ones in the MC catalog.  Do these folded ones crush to seal, or do you use less torque on the fitting and let the rubber, alone create the seal?
My primary use is the Convert loop fittings, 12mm and 14mm ID/32-ish# pressure relief/200f.
« Reply #9 on: August 27, 2017, 09:51:08 PM »
I'm not sure what you mean by "folded", but the ones I linked to do not crush to seal. Less torque on the fitting, rubber does the sealing.
« Last Edit: August 27, 2017, 09:51:52 PM by Antietam Classic Cycle »
« Reply #10 on: August 27, 2017, 10:11:31 PM »
Less torque would be good.  I'm reefing on some of these fittings at fartnivorous torque.
Moto
I see these recommended for drain plugs, but sealing pressure fittings is not mentioned in any descriptions.  Are you using them for oil banjos?
« Reply #11 on: August 27, 2017, 10:22:27 PM »
David, over here they are known as Dowty seals or Dowty washers. Most hydraulic hose and pneumatic hose supply places will stock them.
Offline ITSec
« Reply #12 on: August 27, 2017, 10:56:27 PM »
I checked my tool catalog, and I can't find a torque wrench calibrated in that scale...  :rolleyes:
ITSecurity
2013 Stelvio NTX - Copper
2008 Norge GT - Silver
I am but mad north-northwest!
« Reply #13 on: August 27, 2017, 11:16:45 PM »
The accent is on the 2nd syllable.  As in:  "The differential pinion bearing should always be torqued to the fartniverous before checking preload*."
It's that new-money scale:
nicensnug
gootntite
fartniverous
herniacious
*page 77
Offline Yeahoo Whoyah
« Reply #14 on: August 27, 2017, 11:23:21 PM »
nicensnug
gootntite
fartniverous
herniacious
*page 77
Noteworthy, ha!
Greg Tillitson
El Dorado Hills Calif.
Offline normzone
« Reply #15 on: August 28, 2017, 12:06:43 AM »
Thanks for explaining that - Google was giving me nothing for fartniverous.
Offline Madtownguzzi
« Reply #16 on: August 28, 2017, 01:18:53 AM »
Toyota uses them for oil pan drain plug. The local dealer gives them to me when I buy oil filters for my daughters car.
Randy S.
98 V11 EV
05 HD Electra Glide Classic
Madison, WI
« Reply #17 on: August 28, 2017, 01:46:51 AM »
Google has a hard time keeping up with me.
Offline tris
« Reply #18 on: August 28, 2017, 04:14:28 AM »
I don't think I've ever seen Dowty seals used on brake systems
I'd suggest that you check that the rubber used is compatible with brake fluid to be on the safe side
1993 TW125 "POS" - Resting
« Reply #19 on: August 28, 2017, 04:39:52 AM »
I have seen them used in brake systems but myself prefer to use alluminium washers. Why? Just *Because*.......
Offline dguzzi
« Reply #20 on: August 28, 2017, 02:05:22 PM »
Message me, I have some freebies for you...  In fact a lot of them, various sizes.
« Last Edit: August 28, 2017, 07:16:24 PM by dguzzi »
'03 EVT
'87 Cagiva
'72 Commando
'71 Commando
'13 F150
'16 Mustang
« Reply #22 on: August 29, 2017, 12:52:17 AM »
I never think of Amazon for industrial stuff.
