Author Topic: After market LED Tail light on a V7 - Problem.  (Read 4847 times)
Offline Billy
« on: September 22, 2017, 06:06:23 PM »
I'm trying to install an after market LED taillight on my 1TB 2012(2013) v7r.
Its not working, and I'm running out of ideas. Though I might have missed something obvious.
I'm pretty sure I have the wires connected correctly: The Yellow with Green stripe is the brake light, the Yellow is the running light, and he blue is ground.
Its not working, and I have no idea why.
-The orginal tail light still works, so its not a fuse or other short
-The LED light works as an indicator light if I connect the running light to the left indicator, the brake light wire to the right indicator wire, and ground to ground. So the LED light bulbs work (but I have no idea why this configuration works)
Is this a voltage issue? Or something obvious I'm not aware of?
2012 v7r 1tb
Offline SportsterDoc
Re: After market LED Tail light on a V7 - Problem.
« Reply #1 on: September 22, 2017, 06:13:45 PM »
LEDs are polarity sensitive.
If the unit (combo with turns???) has an LED wired in reverse, it will not illuminate.
That may be the issue.
The factory V7 II schematic shows
B-blue
N-black
Bi-white
to tail/stop
and
G-yellow
B-blue
to license plate light
« Last Edit: September 22, 2017, 06:17:19 PM by SportsterDoc »
23 V7-850 23 Yam XT250 18 Yam Bolt  22 Triumph St Twin  20 CanAm Ryker 14 Honda CB1100 18 Yam XT250 16 MG V7II 17 Yam TW200 12 Triumph Bonnie 02 Sportster 1200S 03 Sportster XLH883 76 Honda 750F 75 Honda CB360 70 Yam CT1 72 Yam CT2 72 Yam AT2 70 Honda SL350 70 Honda CL350 67 Honda CL160 67 Honda C11
Offline Murray
« Reply #2 on: September 22, 2017, 06:31:29 PM »
This check that the sense wires provide power and are not earth switched and check your ground is actually ground.
Offline Billy
« Reply #3 on: September 22, 2017, 06:44:18 PM »
I have tried all combinations, and no go.
It is only a red tail light (brake and running light) not indicators by the way.
I only connected it to the indicator wires to test if the LED bulbs actually worked and hadn't blown.
Pretty sure dark blue is ground on this model (light blue and red are the indicators, yellow and green/yellow are the brake/running lights).
2012 v7r 1tb
Offline Murray
« Reply #4 on: September 22, 2017, 06:52:32 PM »
Got a multimeter or test lamp?
« Reply #5 on: September 22, 2017, 07:20:52 PM »
+1 and/or post data on the light or a link to it.
Offline Billy
« Reply #6 on: September 22, 2017, 08:50:03 PM »
I don't have one unfortunately but I'll go get one. Back soon
Sent from my SM-G935F using Tapatalk
2012 v7r 1tb
Offline Billy
« Reply #7 on: September 23, 2017, 01:20:23 AM »
Tested with multimeter: live wire is close to 12v, and the ground wire is grounding properly. Test Light is working.
Have I missed something obvious like installing a resister? I've tried two LED brake lights now, and neither of them work (connected directly to the wires).
Maybe they're not supposed to handle 12v directly and I've blown both of them? But then one of them works when connected to the indicator wires, so maybe not.
Anyone ever installed an aftermarket LED brake light?
I have no idea what else to test now.
2012 v7r 1tb
« Reply #8 on: September 23, 2017, 02:47:36 AM »
Green /Yellow is a ground colour in many parts of the world.
LED bulbs normally operate on about 3 Volts so there should be resistors inside there somewhere.
Can you give us a part No or something to go on?
Online Old Jock
« Reply #9 on: September 23, 2017, 03:55:17 AM »
According to Carl's diagram for the V7 you are quite correct on you interpretation of the wiring
It does not look like any trickery in the circuit
As mentioned polarity is certainly an issue but it should not be if it's an LED replacement for a bulb.
I ASS-ume no form of canbus on these bikes
Sorry no help just some confirmations
Offline Billy
« Reply #10 on: September 23, 2017, 06:20:27 AM »
-=SOLVED=-
Not a particularly satisfying solution I'm afraid, but solved.
Both tail-lights were faulty. Unbelievable. I tried a third, and it all worked. Cheap tail-lights -- never again (though one of them came from a site many people here shop from). Had to be - the multimeter
suggested the outputs were fine.
Well, now I have a new multimeter to play with, and more knowledge of motorcycle electrical systems.
So thank you all for your replies! Though I feel stupid.
2012 v7r 1tb
« Reply #11 on: September 23, 2017, 09:38:15 AM »
-=SOLVED=-
For most electrical issues, a voltmeter/ohmmeter are indispensable.
Now you can check your battery voltage, etc.
Offline redhawk47
  • Traveler
« Reply #12 on: September 24, 2017, 01:16:12 PM »
Glad you figured it out. If the third unit dies, which may happen considering the quality of the first two:
I installed a Sylvania LED bulb in my OEM unit. A bit brighter than the incandescent bulb, and should last forever. Get the bulb with the red LED.
Dan
« Reply #13 on: September 25, 2017, 08:33:49 AM »
I buy hundreds of bulbs from Superbright
They have a dedicated motorcycle section
https://www.superbrightleds.com
Offline Zinfan
« Reply #14 on: September 25, 2017, 11:59:09 AM »
And most importantly can check the performance of the R/R to see if it is overcharging the battery.  I know the R/R on my 2013 V7 Stone started to do that and I replaced it as have many others.
