Author Topic: NGC BMW Question  (Read 2697 times)
Offline screamday
NGC BMW Question
« on: September 23, 2017, 12:40:48 PM »
I have a niggly little dent in my BMW gas tank that has been there for about 20 years. I have a good friend that has been doing paintless dent repair for about 20 years and he thinks he could probably fix it. He just asked if the tank is doubled walled and I didn't know. Anybody in the collective know if the tank is doubled walled or not? This is a 1988 R100RS
20170923 131929" border="0
« Last Edit: September 23, 2017, 12:42:39 PM by screamday »
Tony in SC
"Comfort the disturbed and Disturb the comfortable"
1988 R100RS
1998 V11 EV
Offline pehayes
Re: NGC BMW Question
« Reply #1 on: September 23, 2017, 01:03:31 PM »
What year and model?  We have an active BMW vintage group here and they will surely know.
« Reply #2 on: September 23, 2017, 01:10:11 PM »
 '88 RS , and unless something changed from '84 it is single wall .
Offline unclepete
« Reply #3 on: September 23, 2017, 03:26:22 PM »
I have never come across a double wall tank . What bike has one ?
That tank is coated on the inside with some red stuff .
Offline Adk.IBO
« Reply #4 on: September 23, 2017, 03:33:00 PM »
I had an '88 RT and a buddy of mine had an '88 RS. Positively single wall tank.
Luke 23:34
Offline screamday
« Reply #5 on: September 23, 2017, 03:48:22 PM »
Thanks guys.....I was guessing single walled but just needed some back-up.
Don't know. He mentioned he has run across them and that he has a separate process for each type. The double walled process is not as successful as the single wall process which is similar to repairing a vehicle fender. Just don't know if he can get his tools in the tank and around the filler neck that extends down into the tank......will see.
Tony in SC
1988 R100RS
1998 V11 EV
« Reply #6 on: September 23, 2017, 05:03:31 PM »
Me neither. Sounds like a solution to a problem that doesn't exist.
Offline wrbix
« Reply #7 on: September 23, 2017, 05:22:07 PM »
Let us know how it goes - have an R100CS (in SC currently) that might could benefit from same.
Bill in VA, sometimes FL
"Eschew aphorism"
LeMans IV - "Giulia"
Lario - "Giulietta"
V50III cafe'd - "Leggera"
‘77 Convert - “Sofia”
Classic Mini
‘60 Austin Healey Sprite
Caterham Super Seven Sprint
‘13 Audi TTRS
Grumman AA5B (sold)
Offline pehayes
« Reply #8 on: September 23, 2017, 06:26:30 PM »
Several responses from a local request all say single.
« Reply #9 on: September 23, 2017, 06:44:21 PM »
My only comment would be that the BMW fuel tank metal appears to be much heavier/thicker than car bodies, and might be more difficult to work with using paint less dent removal (thinking vacuum process like DentWhiz.)  Just an  opinion, not fact.
« Last Edit: September 23, 2017, 06:53:49 PM by ohiorider »
Offline screamday
« Reply #10 on: September 24, 2017, 06:44:31 AM »
 :thumb: :thumb:
He has a large variety of tools, similar to the picture below, he uses to attack the dent from the backside of the sheet metal in single walled construction. He says he uses a "vacuum" process on double walled construction.
Tony in SC
1988 R100RS
1998 V11 EV
Offline wirespokes
« Reply #11 on: September 24, 2017, 10:57:34 PM »
It's very definitely single wall metal. I've removed a lot of dents from that style tank using bent rods with metal balls welded to the end. It can take some time to pull a dent, but the German paint is usually good enough it looks completely undamaged when done.
