Author Topic: Fuel line disconnect on 2012 Norge  (Read 5551 times)
Offline Gramps_Guzzi
« on: September 25, 2017, 08:54:32 AM »
I am attempting to remove the fuel tank on my 2012 Norge but can not disconnect the fuel line.
Any tips on how to do this?
Mike
Offline Scott of the Sahara
Re: Fuel line disconnect on 2012 Norge
« Reply #1 on: September 25, 2017, 09:17:44 AM »
If this is the same disconnect as the 2008 version, I found information at Guzzi Tech that was helpful. If this is the same one, you basicly stick a small screwdriver into the 4 splines that hold it. Once you have loosened a couple of them, it will slip off pretty easy. I have done mine twice in the last month. I am always worried about breaking that plastic fitting coming off of the tank.
Be very careful.
« Reply #2 on: September 25, 2017, 09:24:07 AM »
It has to have no pressure in line, disconnect electric plug, try start bike. Then grasp line in palm w/forefinger and thumb on the grey ring. Push line & coupling towards red elbow, pull back ring towards line at same time as pushing line forward, then yank line and coupling back to pop off. BE VARY CAREFUL not to beak elbow.
« Reply #3 on: September 25, 2017, 11:58:41 AM »
Thanks for the reply and information.
That worked and I did not break the fitting.
Amazing how much stuff is tucked into the frame on this bike, sure doesn't make it easy to work on in a home shop.
« Reply #4 on: September 25, 2017, 01:22:40 PM »
So is it a roller top end or has it been rollerised?
« Reply #5 on: September 25, 2017, 05:46:10 PM »
This one has had the roller tappet modification completed.
« Reply #6 on: September 26, 2017, 12:55:29 PM »
Golden! :thumb:
Offline MGrego
« Reply #7 on: September 26, 2017, 03:22:20 PM »
Why are you removing the tank ?  Inquiring minds want to know......  I've had mine off twice, once to rollerize and once to replace the oil pressure switch.  Replacing it was a bit of an adventure too..
« Reply #8 on: November 04, 2017, 06:58:55 AM »
I needed to access the air filter housing in order to re-attach the small drain line located at the rear of it. Somehow this drain had become disconnected causing an occasional drip of oil onto the exhaust system which resulted in smoke. Don't know when the drain became disconnected but wonder if it may have been at the tappet job which was done by the dealer prior to my purchase of the bike.
Anyway it's fixed now, no more smoke.
What an adventure into working on this bike!
thanks,
Mike
« Reply #9 on: November 04, 2017, 04:17:22 PM »
On mine I've always been able to hold the elbow with my little finger wrapped around and ease the fitting away with my thumbnail as it were.
You are isolating the elbow from any undue bending forces this way.
« Reply #10 on: November 04, 2017, 04:20:32 PM »
Anyway, you can buy the little pliers with appropriate ends the just pop the fittings off easily.
« Reply #11 on: November 04, 2017, 05:42:16 PM »
I think I've seen these pliers packed in sets of 3-4 different sizes.  I've got to find these, since it seems silly to continue going through this exercise each and every time I remove the fuel line from the pump.  Any sources?  And what size works with the connector on our bikes?  I think this deserves a trip to the local Summit Racing store.
Bob
« Last Edit: November 04, 2017, 07:42:50 PM by ohiorider »
Offline dl.allen
« Reply #12 on: November 04, 2017, 10:45:12 PM »
While u are in there with airbox out secure the neutral indictor wire connection on the sensor with a zip tie.  Mine was loose and intermittent.  It a sloppy spade connector on top of a plug
Offline tris
« Reply #13 on: November 05, 2017, 01:00:03 AM »
Bob
The green ones and mine were on Ebay
1993 TW125 "POS" - Resting
Offline willowstreetguzziguy
« Reply #14 on: November 05, 2017, 09:39:06 AM »
If I check Advanced Auto, what would the name of the players be called?
2008 Guzzi 1200 Sport
Offline tris
