Author Topic: Just bought me self a basket case -72 850GT. Update Nov 19.  (Read 7828 times)
Offline craigclu
Re: Just bought me self a basket case -72 850GT
« Reply #30 on: November 06, 2017, 11:44:51 AM »
It will make a nice machine. If that Citroen is yours you've got a great vehicle there as well. I've owned a DS21 saloon and two DS 23 Safaris in the past and they have to be among the best cars I've had.
Kindred spirit here....  Had a DS-19 and a '73 Eldorado.
He who is without oil shall cast out the first rod...”-Detonations 5:72.
Offline RoyRogers
« Reply #31 on: November 06, 2017, 12:29:20 PM »
Jupp, glad to see one more with the same disease :bow:
Regards from Norway,  Roy
1972 850GT
1986 LM IV
1991 BMW K1 with Sidecar
1984 Citroen DSpecial
Offline Steph
  • Cali Stone/ LM3
Re: Just bought me self a basket case -72 850GT. Update Nov 5.
« Reply #32 on: November 06, 2017, 01:02:54 PM »
There are some specialist firms in the UK who can re plate your old chrome bores.
I’m no expert on the subject but came across this topic:
http://www.guzziriders.org/new-cylinder-liners-where_topic8090_page1.html
« Reply #33 on: November 06, 2017, 02:37:33 PM »
I�m no expert on the subject but came across this topic:
Replating is a good way to go if the pistons are still within specs., not scored and are reusable. But, if you have to buy pistons, then the overall cost is the virtually the same as Gilardoni kits.
Offline RoyRogers
« Reply #34 on: November 07, 2017, 12:54:32 PM »
I have looked into replating, but it will be to expensive. Freight cost prohibits....aaand, in Norway replating have exactly the same cost as a complete Gilardoni-set.
And with everything new..I sleep better :wink:
1972 850GT
1986 LM IV
Offline RoyRogers
« Reply #35 on: November 19, 2017, 09:17:25 AM »
Santa Claus was here :bow:
Visiting a gearbox specialist Saturday..
I asked him to replace a few false and destroyed parts..
Nut at the left is incorrect, on the right is correct. The left one was to "short" sitting
to low, meaning..no chance to get that sh.. out. A newly made special socket made it possible to remove, was necessary to apply a light pressure in the tool so be sure it didn't slip
New nut test just to be sure that thread is ok.
Small ball...a 3mm was found, not correct, a 4 mm are now in there.
New seal(s), first of all, get that old thing out.
Old one-piece to the left, new version to the right. Old one was like Bakelite.
With the correct tools, everything is easypeasy
Kaputt
Old O-rings out, one rubber an d one Bakelite.
Everything together, and a test run..
Afterwards we did agree that the gearbox have to be opened. At
least one bearing is shot.
This part was also broken. (pictured are the new part)
Today I took the dynamo apart. Grease was hard and dry,
and front bearing shot. Cleaned everything...and waiting for a
new bearing.
Heads...Exhaust port threads are destroyed in one of them.
I have to different nuts, one original and one ???..no idea
One side..
The other side :cool:
You can't use the left one on the right side an vice versa. Threads
are the same, (when you hold them together they fit in another)
Original nut:
The non-original nut: Threads are a little higher. And this do fit where
the threads are destroyed. (Original nut don't get a grip, this one though)
I was to buy a new head, but after testing today..I have decided
to leave it alone.
Removed the Tyre from front rim. Looks really ....hmm..looks..
I dont' know :grin:.
Cleaning..
Looks a lot better. Did manage  to loosen one of the spokes using
WD40 and a heat gun. I let it alone, until I get a spoke wrench.
More to follow :smiley:
1972 850GT
1986 LM IV
