Author Topic: RPMs at comfy shift points -- Jackal  (Read 5115 times)
Offline webmost
  • Safety Third
    • The Sotweed Factor
« on: October 23, 2017, 02:53:23 PM »
My 2000 Jackal has a bit tall first gear. Shifts up comfy into second at 25mph, into 3rd at 45mph, into 4th at 60, while fifth is strictly a freeway overdrive type thing. No tach... but I believe I am prolly hearing 3500 or 4000 RPM at each shift.
Questions:
Anyone mounted a tach on their Jackal? What tach? How?
if so...
What RPM am I turning ...
at 25mph in 1st? in 2nd?
at 45 in 2nd? in 3rd?
at 60 in 3rd? in 4th?
TIA
Something of a tach addict on my other bikes.
Unmitigated risk aversion is the new Puritanism; complete with witch hunts funny outfits and humorless preachers thundering doom. The Deity is Safety; Satan is a Lawyer; but the object is the same: to suck the life out of life and tell you how to live it.
Re: RPMs at comfy shift points -- Jackal
« Reply #1 on: October 23, 2017, 03:02:42 PM »
I'll just say, your motor likes to rev, and you don't want to lug this motor like a Harley.. it won't hurt anything to wind her out to 7k or more.. happy to cruise all day 4-5k.
a simple tach like this will give you and idea where your at.
https://www.amazon.com/Tachometer-Waterproof-Motorcycles-Tractors-Lawnmowers/dp/B01J9YSJJG/ref=sr_1_2/130-4547568-5512811?ie=UTF8&qid=1508788859&sr=8-2&keywords=motorcycle+tach
« Last Edit: October 23, 2017, 03:03:30 PM by fotoguzzi »
Offline Steph
  • Cali Stone/ LM3
« Reply #2 on: October 23, 2017, 03:08:05 PM »
Down the bottom of this thread, there�s a table with the speed/rpm for your 8:33 drive.
(I was just looking at that yesterday)
http://archive.guzzitech.com/JB-FinalGearSwap.html
« Last Edit: October 23, 2017, 03:09:13 PM by Steph »
Offline Dean Rose
    • Twin Valley Riders
« Reply #3 on: October 23, 2017, 03:40:52 PM »
Ride it like you stole it!  :grin:
Dean
Magnolia '02 EV
Sophia '06 Breva 1100
Offline yogidozer
« Reply #4 on: October 23, 2017, 03:54:22 PM »
your butt is the best judge. luggy, no goody
« Reply #5 on: October 23, 2017, 03:56:22 PM »
 Guzzisteve says "rev it until it shuts off , then shift , repeat"  :laugh:
Offline Bill
« Reply #6 on: October 23, 2017, 04:02:12 PM »
I have an EV with a tach. But it's just not needed, I just shift when it feels right> BTW for normal riding that's about 4000 RPM. The bike speaks to the rider if you listen/feel. For normal cruise I shift to 5th at about 60 mph. For top end speed, stay in 4th.
Bill
Offline wavedog
« Reply #7 on: October 23, 2017, 04:03:20 PM »
While I am no guzzi guru, I have found that the motor in my Jackal is happiest at mid to higher RPM. It seems to smooth out at a higher engine speed. When the motor is warm, and I want to have fun, I will run it up to 45-50 in first then shift into second and run it thru the gears like that. It will hit a hundred in 4th easier than in 5th. I was delighted to find the reserves of speed and power (such as it is) at the higher RPM range. Don't be afraid to rev the motor. I often find myself in 3rd gear running 55 mph and the motor seems to be at the bottom of the powerband for that gear with enough in reserve for easy passing. Try running it up to 40 in first then shift it. It is a lot of fun.
Offline Park Ridge Phil
« Reply #8 on: October 23, 2017, 04:51:24 PM »
 Yes, let it rev up nicely. No need for a tach. Only time I shift to second around 25 is in a small town that would feel like a quite zone to me. I have the Dunstall replica pipes that are rather loud in the higher rpms. 😎
« Reply #9 on: October 23, 2017, 05:40:41 PM »
The engine doesn't even run smooth until 3K rpm. That's all you have to remember, so after you shift to the next gear you should be above 3K accelerating to the next. I normally shift at 5 or above. I prefer the 7/33 gearing instead of a gear I don't use unless I'm over 65mph.
You want to know what mph in each gear is what rpm, well----------I can't remember all that info, especially after a rally.
If it shuts off, skips or goes flat shift.  Now I'm going to have to study the subject cause clearly I haven't been paying attention to it.
Offline Dean Rose
« Reply #10 on: October 23, 2017, 06:02:18 PM »
 :1:
On the 7/33 gearing on my EV.
Dean
Magnolia '02 EV
« Reply #11 on: October 23, 2017, 06:19:57 PM »
I can't even think about 4th until at least 60 and 5th is not even thinking about smooth until mid 70's.
Surfing 3rd on a winding road is just perfect.
kidneb
« Reply #12 on: October 23, 2017, 06:26:44 PM »
TIA
Click the gearing chart and go to the bottom to choose the Jackal with 8/33 rear.
http://www.thisoldtractor.com/guzzitech.dk/dk_da_technical_gearing.htm
It`s in danish, - omdrejninger means revolutions,- hastighed means speed.
      //Ben
Online kidsmoke
« Reply #13 on: October 24, 2017, 06:25:49 AM »
Excellent thread. As my Jackal is the only Guzzi I've ever owned, I've wondered the same. Not worried about it too much, but wondered. This was informative. 3rd gear pushing 5k (now I know!) is an absolute dream!
'79 G5      (Gina)
'93 1000S (Monica)
'00 Jackal  (Claudia)
'09 GRiSO  (Perla)
« Reply #14 on: October 24, 2017, 06:30:37 AM »
I'm with Yogi^^ you don't need no steenking tach
Offline webmost
  • Safety Third
« Reply #15 on: October 24, 2017, 06:42:34 AM »
Don't need it; want it.
I scoped out those charts, but they are all about six gears. My Jackal has just five.
Offline Steph
  • Cali Stone/ LM3
« Reply #16 on: October 24, 2017, 07:08:18 AM »
Yes your bike has 5 gears,
On my link, the charts were probably computer generated, you'll notice that the chart's gear 5 & 6 have the same data.
On the Thisoldtractor link check-out the California tab on the Excel spreadsheet
yw
« Last Edit: October 24, 2017, 07:19:48 AM by Steph »
Offline webmost
  • Safety Third
« Reply #17 on: October 24, 2017, 08:59:04 AM »
yw
My dumb. I didn't notice that there were more sheets off to the left.
From this, it appears I may not be carrying 1st long enough.
Got that tach coming from Amazon.
I like the way my Indian Scout displays. Has a display flipper switch, flips from speedo to tach to engine temp to trip meter to odo. Best of all, it's got a red light in it, just like a binnacle.
Thanks guys
Offline Two Checks
« Reply #18 on: October 24, 2017, 09:06:31 AM »
I wonder if everyone runs their autos in 2nd or 3rd(assuming 4spd)?
No, you dont want to lug the engine but there is no need to spin the snot out of it. If you are at 4rk in 5th thats fine.
1987 1000 SPII "Il Duce' II"
Offline Sheepdog
« Reply #19 on: October 24, 2017, 10:31:10 AM »
The only problem with that chart is the 9-10% optimism built-into Guzzi speedos (on my Vintage, an indicated 70 is a GPS 63mph). Is the chart referring to actual or indicated speed? The digital tach will clarify...
« Last Edit: October 24, 2017, 10:32:08 AM by Sheepdog »
« Reply #20 on: October 24, 2017, 11:58:02 AM »
well now, snapping suspenders, the rev limiter is a safety device and as such should be tested on a regular basis......... :evil:
Offline bigbikerrick
« Reply #21 on: October 24, 2017, 12:41:52 PM »
Do only the fuel injected bikes have a built in rev limiter? anyone know at what rpm it kicks in at? I have never hit the rev limiter on my aluminum. How about old tontis with a dyna III installed, any rev limiter in that unit? when I ride with some" HD friends" is the only time I have heard a bike hitting the rev limiter, but these guys have a penchant for doing it while parked,in neutral.
Rick.
Offline Two Checks
« Reply #22 on: October 24, 2017, 01:29:47 PM »
The carbed bikes will run out of steam and stop winding up all on their own.
Offline Dean Rose
« Reply #23 on: October 24, 2017, 05:06:49 PM »
 :1:
Dean
Magnolia '02 EV
Offline ejs
« Reply #24 on: October 24, 2017, 05:53:26 PM »
:1:
Dean
[/qudote]
Rev limit on my Cali EV are at ca. 8200rpm. Tested almost daily. :Beating_A_Dead_Hors e_by_liviu
California EV 1999
