Author Topic: hollow studs for mounting rear turn signals  (Read 732 times)
Offline wicks
  • Weekend Warrior
« on: November 02, 2017, 01:20:53 PM »
Howdy all. I am changing my 73 V7sport over to the CEV turn signals. I found an OEM set, got the front mount stays new from MGc, and am trying to find the hollow studs in M10/1.5 for the rear signals...I tried to redo old stud with dye, but no-go.
Anyone know where I can buy those rods? Or have an old set lying around? Also can't find them on mcmaster carr, etc...
The originals (Lucas setup) are about 50mm long, dual threaded with a blank spot about 2/3 across the rod...not sure what the original spec was in italy, etc. but am hunting around for a generic hollow stud at M10/1.5/50mm based on the length of the original Lucas installation.
Oh, I'll also have a full set of original Lucas signals and brackets to sell off...all in excellent shape.
« Last Edit: November 02, 2017, 01:22:18 PM by wicks »
'73 Guzzi V7 Sport, '03 BMW GS Adventure, '06 Ducati Paul Smart, '73 911s, '15 G550
Online pehayes
  • Guzzi Hero
    • Guzzi SuperAlce
Re: hollow studs for mounting rear turn signals
« Reply #1 on: November 02, 2017, 01:33:25 PM »
Someone with a lathe could bore a bolt and make these for you quite easily.  Search around local hobby people.  I made my own for SPII.  I could do it for you but the postage probably is more of the nuisance.
Offline wicks
  • Weekend Warrior
« Reply #2 on: November 02, 2017, 02:13:57 PM »
Actually tried the front CEV stems and they don't mount as planned - were supposed to go straight into the headlight bucket but M10 is a far bigger thread than the headlight bolt.
Anyone have a reference / diagram etc on the euro spec parts how these CEVs are to be mounted?
  • Guzzi Hero
« Reply #3 on: November 02, 2017, 02:49:45 PM »
Our local hardware store has table lamp fixing stuff.  Hollow threaded rods are part of it.  Maybe they'll have a size you can work with.
  • Guzzi Hero
« Reply #4 on: November 02, 2017, 04:09:27 PM »
Since the V7 Sport never used CEV signals (only Aprilia and Lucas), you'll have to get a bit creative. If it were me, I make a stem like the originals for the Lucas signals, but with M10 at the signal end.
« Last Edit: November 02, 2017, 04:54:33 PM by Antietam Classic Cycle »
http://www.AntietamClassicCycle.com
'69 V700
'69 Ambassador
'76 Convert
'13 V7 Stone
Most used word in my vocabulary lately: "whatever", usually delivered with all of the disdain of an aging Valley Girl...
Offline wicks
  • Weekend Warrior
« Reply #5 on: November 03, 2017, 02:27:44 PM »
Oh wow, I've made a mistake, thought they came originally with CEV. Will be looking for those aprilia ones!
  • Guzzi Hero
« Reply #6 on: November 03, 2017, 03:11:17 PM »
Aprilias won't be easy to find, in my experience. Maybe Lucas like the US delivery bikes used instead? Repros are easy to find of those. Contact Jim/"canuck750" here - maybe he can help.
'69 V700
'69 Ambassador
'76 Convert
'13 V7 Stone
Offline malik
  • Guzzi Hero
« Reply #7 on: November 03, 2017, 03:31:50 PM »
They look very similar to the broken one on a Trident I came across recently. The owner was swearing at Lucas & bemoaning the the fact that it had again broken. You're probably better off replacing the rod with something more reliable than another Lucas unit, but if you want original-looking, try via the Trident/Rocket forums in the UK.
Offline canuck750
  • Guzzi Hero
« Reply #8 on: November 04, 2017, 11:35:26 AM »
European issue V7 Sport used Aprilia signal lights, great quality cast bodies with sprung lamp holders, of 7/16" threaded couplers to the stems. North American imports got Lucas lights, plastic bodies, much cheaper quality.
There are plenty of Lucas type lights available, MG Cycle sells them. Aprilia are rare, I scour Ebay for them and buy them when I can find decent ones. The Aprilia lens is reproduced, Bevel Heaven sells the, $50 a pop, I make my own repro lens.
The stem mounts for the front are unique to the V7 Sport, I made up a batch a couple years ago but none left. I do have the water jet cut tear drop tabs that you can use to weld up and chrome your own.
Front with Lucas
Rear with Lucas
Aprlia rear
« Last Edit: November 04, 2017, 11:38:26 AM by canuck750 »
1949 Guzzi Airone
1958 Guzzi Cardellino
1972 Guzzi Eldorado
1972 Benelli Enduro
1973 Guzzi V7 Sport
1973 Laverda SF1
1973 Benelli 650S
1974 Guzzi 750S
1975 Ducati 860 GT
1978 Moto Morini 500
2015 KLR 650
2016 BMW K1600
SOLD
1975 750 S3
Offline wicks
  • Weekend Warrior
« Reply #9 on: November 06, 2017, 05:29:15 PM »
Oh thanks so much. Yes, the aprilia ones are very nice. I already have the original lucas set all in perfect shape, thanks though.
Happy to swap if anyone prefers the lucas setup! :)
