Author Topic: V85 TT Merged Threadfest  (Read 642748 times)
Online john fish
Re: V85 TT Merged Threadfest
« Reply #1800 on: July 04, 2019, 08:30:48 PM »
I wonder if this explains what I thought was my difficulty in finding 1st gear from neutral?  From an Australian review:
The other annoyance is that while there is a gear position indicator, there is no gear position sensor on the gearbox. Instead the ECU works out what gear it is in via a combination of RPM and rear wheel speed. This means that when you are sandwiched between two trucks after lane-splitting to the front of the traffic lights the neutral light does not go out until you start rolling, which had me on tenterhooks when the lights went green as to whether I was actually in gear or not
https://www.mcnews.com.au/moto-guzzi-v85-tt-review-motorcycle-test/
I've been told by a friend that the gearbox does have a neutral switch.
He lost the run of himself.
« Reply #1801 on: July 04, 2019, 08:38:09 PM »
Part#48
It's a neutral switch. Yes the gear selected is calculated by a road/engine speed comparison but the neutral light is still governed by a simple switch. My guess is if it isn't going out until the bike moves it's more likely to be an issue with the dogs not mating until the shafts spin and the pawl spring exerting force on the drum completes the engagement as the clutch is released and the drum turns enough to activate the switch.
If there is one thing Guzzi have got very good at in the last decade and a bit it's gearboxes. The only thing I find a bit odd is they've dropped the oil pump. I'll have to look a bit and see if they've reverted to needle rollers under the pinions, that would be nice.
Offline jacksonracingcomau
« Reply #1802 on: July 04, 2019, 09:57:05 PM »
Yeah but
Hedges mcnews test infers light comes on when already in gear then pulling clutch in to stop
Parts book makes that sound unlikely unless sender on his was Friday one (or 70’s leftover)
I’m doubting him
« Reply #1803 on: July 04, 2019, 10:26:56 PM »
He's a moto 'Journalist' which means he wouldn't know his arse from a hole in the ground.
Offline Glawster
« Reply #1804 on: July 05, 2019, 02:20:36 AM »
Neutral light seems to work normally to me!
One issue though is that the gear indicator goes out when the clutch is pulled in, so if you forget what gear you're in at a standstill you only find out when the clutch is engaged.
To be honest though, first gear is so low I'm preferring to set off in second.
1955 Falcone Sport
2021 BMW R1250R
Offline frans belgium
« Reply #1805 on: July 05, 2019, 03:45:50 AM »
Right, that is a bit annoying.
None of my previous Guzzis had gear indicators, and I didn't miss them.
My previous Bmw had an indicator that showed gears at all times, and I very quickly got used to that.
And now, I'm bothered from time to time that the V85 waits until the clutch is released to show the actual gear.
One gets very easily spoiled ;-)
And yes, first gear is low, but setting off in second ?  I wonder if that wouldn't kill the clutch in the long run? I won't do it.
« Last Edit: July 05, 2019, 03:49:15 AM by frans belgium »
Owned and sold: V65, Nevada, 2xCali, Breva 1100, Norge 8V, Breva 1100 with Squire sidecar
Currently own: V85 TT
Offline pauldaytona
    • Paul's fast Guzzi Page
« Reply #1806 on: July 05, 2019, 12:57:06 PM »
in 1977 I had a Suzuki GS550 that had a gear indicator that worked perfect. So what is new, on one side I don't need/want one, for the other part of the world who is happy with it, it should be there. ANd if it can work without some mechanical switch that can break, fine.
Paul
Daytona 1225, Stelvio 1151
Offline keener
« Reply #1807 on: July 06, 2019, 07:39:53 AM »
 try covering the gear indicator with a bit of tape so you cant see it and  ride the motorcycle ...after a while  you probably wont miss it  :whip2:
problem solved
« Last Edit: July 06, 2019, 07:42:09 AM by keener »
smile and tremble
1974 Z1 Kawasaki since new
1998 Suzuki 1200 Bandit
2005 Ducati Multistrada 1000s
2007 Guzzi 1100 Griso
2015 Kawasaki Versys 1000
« Reply #1808 on: July 06, 2019, 07:43:06 AM »
Can I ask why you would EVER need it ?
If you need a different gear, will knowing which one you’re currently in, make any difference ?
Offline keener
« Reply #1809 on: July 06, 2019, 07:44:37 AM »
smile and tremble
Offline Kiwi Dave
    • Guzzi Gander Ltd
« Reply #1810 on: July 06, 2019, 04:25:20 PM »
The V85 is lower geared than my previous Guzzis.  I keep trying for 7th gear, the indicator is a beacon to stop trying.
« Reply #1811 on: July 06, 2019, 05:18:00 PM »
I ride by the "feel' of the engine, and actual speed by the rev counter.  My Breva came with mph/kph speedo, and it is BUSY.  We ride on the other side of the road from the States, the rev counter is on the right hand side of the dash and it is much easier to read the rev counter. (100kph = 4000rpm) Also, oncoming traffic comes at me from the RHS and a few too many tourists in their camper vans means that eyes focused up ahead is good.
I haave at times tried to change in to 6th gear though :embarrassed:, when she is warmed up it does like that 5000rpm band. :grin:
« Reply #1812 on: July 06, 2019, 06:17:42 PM »
Don from the local dealer was riding this one today.  Maybe I'll get a test ride on it?
Offline sliphorn
« Reply #1813 on: July 07, 2019, 08:09:31 AM »
I hope you get a chance to ride it. I found it to be perfect for me and probably the nicest motorcycle I've ever ridden.
« Reply #1814 on: July 07, 2019, 02:43:13 PM »
They are nice, but whatever you do don’t buy that colour mate..
It looks like Bulgarian Army surplus !
Also that bash plate will be coming off mine in the first 5 minutes.
« Last Edit: July 07, 2019, 03:44:04 PM by Huzo »
Offline Darren Williams
  • Finally got me a Griso!
« Reply #1815 on: July 07, 2019, 04:46:30 PM »
Saw him ride in on it at Pops. He let me take it for a spin (out to Luther and back). I was pretty impressed with the bike. Guzzi has done a nice job on the bike. If there are no "new design" big issues with it, could be as popular as the V7 series.
« Reply #1816 on: July 07, 2019, 05:03:54 PM »
well doggon it, Darren.  I rode to Pop's yesterday.
How's it compare to your Stel?
Offline Devildog
« Reply #1817 on: July 07, 2019, 05:19:58 PM »
Is the skid plate at all functional? It looks too light in pics.
This one on my dirt bike isn't pretty but it works.
'93 Daytona 1000
'95 Sport 1100
2002 Aprilia RSV Mille R
'10 GasGas e250 FE
« Reply #1818 on: July 07, 2019, 06:03:51 PM »
Much lighter, very neutral and stable handling, and smooth power. The Stelvio is much heavier and more raw power, with a lot more vibration. The power seemed pretty linear and adequate but not over the top that gives a rush. The throttle was just a little bit snatchy at 3000 RPM (I repeated to make sure what I was feeling) but at 4000 RPM was very good. It revs very freely and 0 to 70 was just churn through the gears, going pretty quick. I was only able to run it up to 85 but up there it's power starts to show a little lacking compared to other middle weight bikes. Even with the extra weight, the Stelvio felt like it would go 60 to 100 MPH much quicker.
I was riding the GS so comparing it to that was similar ergos with less weight and less power. I couldn't help trying to compare it with my FJ09, softer suspension maybe a bit more stable, not as crisp handling and about the same amount of power if the V85 in sportiest mode and the FJ09 in rain mode "B".  That said the FJ09 is kind of "frantic" power wise, it likes to go and go quickly.
All that said, I think the V85TT hits the mark dead on for what it was designed for. It's not a hooligan bike, but a very capable do anything bike. Maybe when I get older and more mature.
« Reply #1819 on: July 07, 2019, 06:08:08 PM »
I am probably not old enough for the intended customer.
« Reply #1820 on: July 07, 2019, 06:24:42 PM »
It won't have that "rush" you want when you twist the throttle.   :grin:
For those type of bike ergos, you would probably want a Multistrada 1200, to go with the Ducati shirts you have. I would recommend the Pikes Peak model.   :drool:
« Reply #1821 on: July 07, 2019, 06:31:02 PM »
If you haven't guessed, I not particularly fond of Adventure style bikes. I have a friend with a GS and he's been trying to get rid of it for years- that's gotta tell ya something.  But yeah, I'd probably prefer the one described over the others.  But I like a bike with a little bit of tuck .......
« Reply #1822 on: July 07, 2019, 06:39:22 PM »
That's only because of the "BMW" cost to repair part, not the riding.
« Reply #1823 on: July 08, 2019, 04:13:57 AM »
Bugger you Derek (Glawster)
I just set myself back 8 weeks in my quest to own a V85.
I had first dibs on a red/white one but relinquished that opportunity to wait for one of the TWO red ones to come to Oz in October...  :sad:
Rosso Volcano apparently.
Still, what else was a bloke to do ?
It’ll go nicely with this..
« Last Edit: July 08, 2019, 04:20:26 AM by Huzo »
« Reply #1824 on: July 08, 2019, 05:38:39 AM »
It’s garbage..
Offline sliphorn
« Reply #1825 on: July 08, 2019, 12:30:18 PM »
I hear ya! That was the color I rode and I agree. Looks like a Bulgarian Makarov. Will you replace the bash late with something in the aftermarket?
« Reply #1826 on: July 08, 2019, 10:38:36 PM »
Yes mate.
There’s a fiendish plan afoot as we speak..!
« Reply #1827 on: July 08, 2019, 10:39:27 PM »
It’s garbage..
Sorry mate.
The standard V85 one, not yours.
Online bad Chad
« Reply #1828 on: July 09, 2019, 04:26:21 PM »
Are v85s on the sales floor in the USA?
Offline Zinfan
« Reply #1829 on: July 09, 2019, 04:28:07 PM »
Over at Advrider there are a couple of guys who have picked up their bikes, I'm still waiting to hear word on mine showing up here in California.  Af1 Racing has a grey one listed as in stock on their webpage.
« Last Edit: July 09, 2019, 04:33:08 PM by Zinfan »
