Whatever the Stelvio is or is not, I've seen a guy ride circles around several top notch naked street bikes. Enough so to make them look foolish. With the right pilot that overweight bike can embarrass almost anything in the twisties.But, I digress............ ...........
Weight, seat height and fuel capacity please.NC
Quote from: PeteS on September 11, 2018, 10:46:44 AMIts supposed to be an adventure bike. Isn't the whole point to make a bike to compete with the BMW 800GS and Triumph XC 800s? The Stelvio was never an adventure bike, just a grossly overweight streetbike. Give that man a cigar
About the motorhttps://translate.google.com/translate?sl=it&tl=en&js=y&prev=_t&hl=en&ie=UTF-8&u=https%3A%2F%2Fwww.motociclismo.it%2Fmoto-guzzi-v85-segreti-motore-intervista-cappellini-70088&edit-text=
Quote from: PeteS on September 11, 2018, 10:46:44 AMIts supposed to be an adventure bike. Isn't the whole point to make a bike to compete with the BMW 800GS and Triumph XC 800s? The Stelvio was never an adventure bike, just a grossly overweight streetbike. Hundreds of folks have done that ride on Goldwings and Harley dressers. Whats the point? There are Goldwingers who can ride circles around sport bikers. Just becuase you can ride them on roads, including gravel roads and even ride them fast doesn't make it a dual sport.Pete
I think the long travel suspension on most ADV bikes has a lot more to do with it than anything else. Track times are irrelevant as soon as you throw sand, frost heaves and broken pavement into the mix. A suspension set up on the soft side can be hugely beneficial depending on the road surface and that's counter intuitive for most squids. <SNIP>
I'm new to the Moto Guzzi world (bought my first one Feb 2018!).I'm assuming first year models have some issues to sort out? Like I would not buy a first year KTM model where they have a new engine platform (like the 790). Any thoughts/concerns about this?
+1 The suspension will be key for me. Was this || close to buying a Stelvio instead of the V7 for that reason but chose lighter weight over better suspension. The V85 could be that middle ground between the two. I guess I'm after an F700 with character. I loved the way that bike rode but the engine was a buzzy industrial lump that did nothing for me.
Guzzi tends to evolve the drive train rather than start from scratch with a new design. Yes, they will claim that the new mill is a total redesign. Still, for the most part they are building on the tried and true big or small block lump.
The Lario 4V/cyl. motor was largely based on the existing tried and true small block lump.Look at all the problems they had with valves dropping.Granted, the Lario had an all new valve train, where the V85 motor does look to be more of an evolution of the V9 motor.
Nutz
Even more more recent news. This article says it was officially unvieled last Friday-Sunday. And there will continue to be doubters Avialable at a dealer near you...? Spring 19 https://www.google.com/url?sa=t&source=web&cd=1&ved=0ahUKEwj-tNrd5rjdAhXLdN8KHZFFA90QqOcBCAwwAA&url=https%3A%2F%2Fwww.motopinas.com%2Fmotorcycle-news%2Fmoto-guzzi-debuts-the-production-v85-tt-modern-classic-enduro.html&usg=AOvVaw14WfonNnBt5rG5jeB528Zd
The following is not held up as a definitive document on the Physics involved but for anyone interested..If you imagine a bike coming toward you on an arbrirary angle of lean, let's say for simplicity 45 degrees.We know that the resultant of the vectors act through the Centre of Mass, in this case it will be somewhere between the rider's wedding tackle and his blurter.I'm assuming guys outside Oz are similarly blessed as us in the downstairs department, but I will stand corrected.Anywayyy..Here comes our hunky hero on his red 10 year old Norge leaning at a seemingly suicidal aforementioned 45 degrees and all is well.If you imagine a rope hanging vertically from his nether region with X force being supplied by gravity, were it not for the fact that there is another force at play, our intrepid rider would be slammed down on his side and the ride would be over.But help is at hand...Fortunately Sir Issac Newton saw to it that there is also a horizontal force trying to stand the bike upright, and this is referred to as Centrifugal force, (actually erroneously since it is only the equal and opposite reaction to the Centripetal force turning the bike around the corner, but if we may go on..)If you can conjure the image in your mind, you have a vertical pull on the imaginary rope downwards toward the Earth's core and an equally strong force pulling horizontally toward the horizon, (a tangent if you will)..Clearly if these forces are equal, the bike will remain in balance and this is the case 99.995% of the time.It can be seen if you examine the diagram that you have drawn in your head, that it will not matter how far up from the road these two "ropes" are pulling, that is, how high the C of M is, balance is restored and the sum of forces is zero within the system..If the above example leads you to some level of concern regarding ropes and wedding tackle, fear not, it was an attempt to give an Earthy type analogy to a theoretical discussion.Ok then..Harness secure.. Here we go
I understood most of that. But what then changes when you lean your upper body and head closer to the mirror on the downside. I mean my wedding tackle is still tickling the shifter either way, but I've been taught by a riding instructor that "kissing the mirror" like that reduces lean angle for a given speed.
"kissing the Mirror" .... ???? ..... You sure you're not a Closet BMW rider???
Yes I did say ...and exactly my point... thank you :) When this all started a year ago a significant contingent said it would be many years if it ever happened Just gotta have a little faith and cough up the dough
Please!!!I am color blind anyway, just give me the bike!rant over
Yeah Kev it does, it's a fair point you make.But.Leaning the bike one way, will necessitate leaning your body the other, thus keeping the all important Centre of Mass on that imaginary line down through the bike to the road.
