Author Topic: Hydro Cali cam kits?  (Read 1671 times)
« on: November 08, 2017, 07:16:06 PM »
Anyone remember the part# or know where I could find one?
Re: Hydro Cali cam kits?
« Reply #1 on: November 08, 2017, 07:59:59 PM »
Thanks, I've got the tools. Just got a buggered one in though and it needs kit.
887349 is the supervision number for the kit.
« Last Edit: November 08, 2017, 08:15:31 PM by pete roper »
Orange Guzzi
« Reply #2 on: November 08, 2017, 08:41:47 PM »
I believe 03049872 was the part number of the final "Refitting Kit".
03049871 was the "Hydraulic Tappets Refitting Kit Tools"
I've got PDF of the parts list and procedure if you need it.
Can you share the PDF?  I have a couple of images of the tappet and tool with dimensions.  They tappet dimensions do no match what I pulled from my engine.  Mine are longer.
See my post regarding checking the recall work after installation.  I found the rocker arm pad and the valve stem were both damaged and 3 of the 4 tappets stuck fully extended.
Also appears that there is low oil flow thru the rocker arms and onto the valve stem.
« Reply #3 on: November 09, 2017, 02:00:12 PM »
Pete, if you can find him, I think Mike Haven had some kits at MPH before the bad stuff happened.
