Author Topic: Battery Bracket for Tonti Frames  (Read 2048 times)
Offline Stephen Hill
    • Wildgoose Chase Moto Guzzi
« on: November 09, 2017, 09:50:51 PM »
I am looking at putting a smaller battery in my 1976 LeMans, and see that Harper's sells a bracket for the Tonti framed bikes to hold an Odyssey PC545.
Info found here:  http://www.harpermoto.com/pc545-conversion-battery-bracket-for-tonti-frames.html
Has anybody used this bracket?
I see the reference to it attaching to the sidecover bracket, but I am not sure how that works.
Any comments on how easy it is to install and uninstall the bracket?
While I am working the battery area, I would really like to get the seat right out of the way.  It pivots up, but it is still in the way.  Should all the wiring to the rear fender, brake lights, and rear turn signals easily disconnect from the bike so the seat/rear fender can be totally removed?  It's a PITA working around it.
Stephen Hill
1977 Moto Guzzi LeMans Mk1
1989 Honda NT650, 1999 Honda VFR
1956 BSA Gold Star, 1968 BSA Royal Star
1968 Triumph Bonneville, 1969 Triumph Daytona, 1973 Triumph Trident
1968 Norton Fastback, 1969 Norton 650SS, 1972 Norton Commando Combat, 1974 Norton Commando Interstate
Offline Turin
Re: Battery Bracket for Tonti Frames
« Reply #1 on: November 09, 2017, 10:40:13 PM »
Sidecover bracket installs with a couple of nuts and bolts. You may have to drill a hole in it to use this (depending on the year or side). The 850T and tonti's with tool boxes will require you to bake a bracket, easy enough with a piece of flat stock.
1985 Sidlow Guzzi
Offline Dharma Bum
« Reply #2 on: November 10, 2017, 09:50:31 AM »
What should the oven be set at for that bracket?
« Reply #3 on: November 11, 2017, 03:57:48 AM »
I have Harper’s bracket on both my old LeMans’ works great. You do have to drill a hole in the bracket under the side cover for one bolt. It makes room for a bank bag with a few tool shop.
Offline acogoff
« Reply #4 on: November 12, 2017, 07:56:57 AM »
     What works is to put in a 680 battery with some homemade shims on one or both sides to compensate for the narrower than stock width  and use the stock strap on top. Simple and costs nothing.
Marshall County Minnesota USA
