Removed electronic petcock, now what do I use that power source for?
Topic: Removed electronic petcock, now what do I use that power source for? (Read 1076 times)
Edgo897
Hatchling
November 17, 2017, 08:01:24 PM »
Will that wire support auxiliary headlights? I'm sure it can do a phone charger. What else can I use it for?
Ed
fotoguzzi
vee git tooh soon oldt und too late wise -my Dad
Re: Removed electronic petcock, now what do I use that power source for?
Reply #1 on:
November 17, 2017, 09:24:54 PM »
just kidding..
Kiwi_Roy
Reply #2 on:
November 18, 2017, 03:44:56 AM »
Put a small 12Volt LED there as a troubleshooting aid.
If you get a bad ignition switch, kill switch or stand switch the light will go dim, go out or flicker.
If the light is out chances are the bike is not going to start.
BTW the light has been named a "Go Winkie" over on the other board.
Last Edit: November 18, 2017, 03:50:12 AM by Kiwi_Roy
Zoom Zoom
Reply #3 on:
November 18, 2017, 05:28:44 AM »
It would support a headlight as long as you use it to trigger a relay. I would not run a lot of watts through the wire. You could probably use it for something that is a light load, such as a GPS, volt meter, something like that. If you use it to trigger a relay, use it for whatever you like.
John Henry
