My biggest concern was the cooling system. It's summer here now and where Mark lives it gets as hot as hades in summer, weeks on end of 40*C are not unknown. If it's going to pop it's clogs due to cooling problems we'll know soon enough.Michael put a lot of thought into addressing the cooling issues. As I said before, this project is mostly his and Mark's. I can take little credit.Pete
Are you thinking of doing a similar job on your hooligan bike Pete?
Not right at the moment, I can't afford it. Once I've ridden it when it's mapped up properly I'll decide. My guess is it will be a very hard choice not to build one for myself.I also need to get my original engine block back from Ron so I can work out a way to install an early type front main bearing into it. All our attempts to find a bearing manufacturer who would supply us with a press in bearing at a reasonable price have come to nought so my next 'Plan B' is to fit an earlier type main. All the mounting bosses etc. are still cast into the case. The crank journal is the same length. We can at least try. If that can work I could build a 1400 into that and return my bike to its original engine # which would be mildly amusing in a slightly mad sort of way.Pete
Getting the older type bearing isn't the problem Paul. It's the construction of the new front one which is effectively just a pressed in sleeve in the case that presents the problem.Pete
Y'know, somewhere, in the sort of base, reptilian hind-brain of my soul I really wanted this to be a wash-out. I love my 1200 and really, I don't need anything more than what it offers. But then we built this thing and it sounds like a lot of fun. And one day, soon, I'll get to ride it, and then I think I can see another huge haemoragic loss from my bank account and a lot of weasling by way of excusing it! Pete
I don't know what your tax laws are like in Oz, but, here in the US, you'd build one for yourself and write it off your taxes as "Research & Development."
In the 'States, what would happen if you did that (and I'd be thrilled to bits if Pete could do it here), and the thing let go and locked the arse end up resulting in a crash that killed someone.Would some bottom dwelling ambulance chasing litigator, hound you to the ends of the earth and relieve you of everything you own ?Just the sort of crap that would stimey the efforts of guys like these..
That is why you incorporate and have liability insurance. The corporation is the legal entity and is the one that gets sued.
S'all good! I reckon the real fun will be between 3.8 and about 7. Above that VE will drop off sharply and worse than the 1200 but in that range I think the 'Pull down the front of the Royal Hotel" scenario will be realisable.
