Author Topic: Borrani Rims..how to rehabilitate those ??  (Read 4133 times)
Offline RoyRogers
« on: November 23, 2017, 10:16:29 AM »
Looking a little used and ugly, any good recommendations?.
Have tried this one..
works pretty good, at last, steel wool and polish. But there are to many stonechips (?), and the cannot be remove very easy.
Hydroblasting a alternative? Or sandblasting and powdercoating?
Spokes comes loose without raw force.
No I am not buying new ones  :laugh:
Regards from Norway,  Roy
1972 850GT
1986 LM IV
1991 BMW K1 with Sidecar
1984 Citroen DSpecial
Re: Borrani Rims..how to rehabilitate those ??
« Reply #1 on: November 23, 2017, 10:29:18 AM »
Start with either soda blasting or vapour blasting the bub and rim, follow up with an orbital sander 500 grit on the rim surface
It should get to this before polishing
Flat file the rim lip to remove deep gouges or nicks (too a point)
I start polishing with a rough sisal wheel and medium grit polish followed by a fine buffing wheel and fine polish
This hub was soda blasted, vapour blast finish looks better though
« Reply #2 on: November 23, 2017, 10:33:54 AM »
My Mille's original front hub was about that bad, and I was able to get it decent looking by using a
Cal Custom Purple Metal Polish and Deoxidizer kit (2 bottles) with a scrub brush, and then minimal
rubbing with a Scotchbrite pad.  I was going for decent-looking though, not show-polished.
« Last Edit: November 23, 2017, 10:36:40 AM by Triple Jim »
Offline RoyRogers
« Reply #3 on: November 23, 2017, 12:29:01 PM »
Thanks a lot to both of you.  :thumb:
I'l try it out, it will take a few days..
1972 850GT
1986 LM IV
« Reply #4 on: November 23, 2017, 12:48:16 PM »
I'm not sure what's available to you chemical-wise in Norway, but here in the 'States we have NAPA Aluminum Brightener:
Spray it on, let it foam up and work a while then use a pressure washer to rinse it off. Works very well. Perhaps you have something similar available?
Then, if you want it shiny, any number of aluminum polishes will do the job.
Offline Don G
« Reply #5 on: November 23, 2017, 02:28:22 PM »
 :1:
Charlie has got it right, no point taking your wheels to bits, I use a product that Truckers use on polished aluminum, on crusty areas such as the hubs give it a couple of applications with high pressure wash with hot water. Then a bit of polish such as Solvol Autosol or Mothers , less work and less time than a complete strip down.  DonG
« Reply #6 on: November 23, 2017, 05:46:04 PM »
:1:
I would tend to agree unless the inside of the rim shows significant corrosion, I have seen rims where the spoke nipple opening is dangerously corroded with little structure left to support the spoke tension, more so with steel rims but I had a Borrani front rim that was too far gone to use.
Example of a steel rim that looked good on the outside
And acid washing will not get the corrosion trapped on the nipple and the nipple hole in the rim until the nipple and spoke is removed
« Reply #7 on: November 23, 2017, 07:57:53 PM »
And acid washing will not get the corrosion trapped on the nipple and the nipple hole in the rim until the nipple and spoke is removed.
For that, I use a variety of stainless steel wire brushes in my Dremel. The little "cup" brushes are perfect to get down around the nipples. Still might not get it all, but then not every wheel has corrosion there.
Offline John Ulrich
« Reply #8 on: November 23, 2017, 08:11:53 PM »
Take em apart.
Eagan, MN & Scottsdale, AZ
MN MGNOC Rep  L#800
Offline RoyRogers
« Reply #9 on: November 25, 2017, 06:18:32 AM »
As suggested, I have taken them apart. Just to be sure all old goo are removed..
look at the rear rim :rolleyes:
Did file those nicks and burrs..to an extent.
Spokes cleaned
All the rest are to be (wet-) glass-blasted. I will deliver all parts Monday and talk it over with the guy
actually doing this.
I did try some aluminum chem, strongest I could get, no way. Due to environmental laws that
"good old stuff" are long gone.
1972 850GT
1986 LM IV
Offline RoyRogers
« Reply #10 on: November 25, 2017, 06:32:28 AM »
Next:
It seems to me, that something is missing, shim(s) perhaps??
Both sides of the rear wheel hub have those marks pictured.
Found this picture in another thread, like it ought to be.
http://s249.photobucket.com/user/canuck750/media/1974%20Guzzi%20750S/DSC04920_zps4vzbcdle.jpg.html
http://wildguzzi.com/forum/index.php?topic=80897.msg1274237#msg1274237
1972 850GT
1986 LM IV
Offline RoyRogers
« Reply #11 on: November 29, 2017, 12:36:05 PM »
Came out ok.
Cleaning, etch-primer and some colour..
I like it like this, others may not.
Thank you for your advises :thumb:
1972 850GT
1986 LM IV
« Reply #12 on: November 29, 2017, 01:53:41 PM »
Nice work, the wheel looks great! :1:
Offline RoyRogers
« Reply #13 on: January 08, 2018, 09:00:58 AM »
I have cleaned those rims inside and sprayed one round of etch primer and rim paint. Should I do something more to protect the inside? (Underneath that rubber rim strip)
1972 850GT
1986 LM IV
« Reply #14 on: January 08, 2018, 09:40:28 AM »
I'd think you are good to go..
« Reply #15 on: January 08, 2018, 10:37:19 AM »
Should be good for at least another 40 years!
Offline RoyRogers
« Reply #16 on: January 08, 2018, 11:02:41 AM »
1972 850GT
1986 LM IV
« Reply #17 on: January 08, 2018, 12:16:42 PM »
