Author Topic: V700 drivetrain rebuild  (Read 40108 times)
« on: November 26, 2017, 05:57:24 PM »
Here's a link to a photo album I created for a customer's V700 drivetrain rebuild project. Captions are below each photo. It will be added to as the project progresses.
https://flic.kr/s/aHsm48h8as
« Last Edit: November 26, 2017, 05:58:36 PM by Antietam Classic Cycle »
Offline TRw1
Re: V700 drivetrain rebuild
« Reply #1 on: November 26, 2017, 07:36:31 PM »
Charlie,
Really interesting!  Thanks much for posting.  Helps us "less mechanically inclined" learn a lot.
Ted
Offline MotoMatt
« Reply #2 on: November 26, 2017, 08:12:59 PM »
Thanks for sharing! How many miles were on this motor? I'm curious why the valves were so eroded.
« Reply #3 on: November 26, 2017, 08:35:32 PM »
I'm not sure how many miles were on it. I think water in the cylinder may have been involved in corroding/eroding the valves.
Offline SED
« Reply #4 on: November 26, 2017, 09:19:58 PM »
Great photo essay Charlie.  Really appreciate the captions with their information and evaluation of the condition of parts - usable or not.
Thanks!
1983 LeMans III
1981 Monza
1947 Ariel Red Hunter
1939 Ariel Red Hunter
1937 Guzzi GTV
« Reply #5 on: November 27, 2017, 10:39:56 AM »
Fantastic photo log, that drive line sure looked tired but it looks like new now!
Offline m13
« Reply #6 on: November 27, 2017, 02:53:27 PM »
speedo showed 22881
Leonardtown, Maryland
'69 Manky V700
'60-something?(who really knows) Chang jiang 750
http://www.youtube.com/watch?v=PORS0y5exgY
http://www.youtube.com/watch?v=B24-c-rJM_Q
Offline Lesman
« Reply #7 on: November 28, 2017, 01:33:12 PM »
great pictures
Offline Rick4003
« Reply #8 on: December 03, 2017, 12:58:28 AM »
Hi Charlie,
The pictures look really good, nice walk-through of the process.
Did you get the crank balanced for the new pistons, or is the 15 gram difference not enough to warrant a rebalancing?
What is the purpose of the intake reducers? Increase intake velocity?
Thanks for posting the album :)
-Ulrik
Moto Guzzi Ambassador - 1967
Yamaha FZR 600 - 1996 - SOLD
« Reply #9 on: December 03, 2017, 03:50:22 PM »
Hi Charlie,
-Ulrik
A different piston pin brought the piston assembly up to weight.
Guzzi made the ports way too big on the early heads, the reducers are to correct that and maintain proper intake charge velocity. They run like crap without them. Been there, tried that, didn't work.  :wink:
Offline Rick4003
« Reply #10 on: December 03, 2017, 10:32:42 PM »
Ah okay, I was wondering if it wouldn't be a problem if you didn't match the weight of the old pistons.
Makes sense with the reducers if the heads have a too large bore to keep velocity up.
Thanks for clearing it up
-Ulrik
Sent from my SM-A520F using Tapatalk
« Reply #11 on: December 08, 2017, 08:52:47 AM »
Lots of photos added recently, getting pretty close to the end of this project.
Offline Bluerobotz
« Reply #12 on: January 29, 2018, 07:09:08 AM »
Thanks Charlie, I enjoyed this one. Great job!
2003 B750, 1984 GPz900R A1, 1985 GPz900R A2, 1981 V50 Monza, 1973 Eldorado Civilian
Offline bigbikerrick
« Reply #13 on: April 24, 2018, 12:10:00 PM »
Fantastic job, and pictures, Charlie! I love to see stuff like this. What did you use as a "cushion" between the generator, and the engine case "saddle", was that a bearing shell with a hole drilled in it?
Thanks for posting this!
Rick.
« Reply #14 on: April 24, 2018, 06:39:48 PM »
Rick.
Aluminum sheet of the appropriate thickness, cut, drilled and curved to fit.
Offline tetarabra
« Reply #15 on: April 25, 2018, 03:26:35 AM »
Nice job  :thumb:
I tried the alu sheet but it desintagrated . Switched to stainless steel sheet . It has worked a treat for years.
Offline m13
« Reply #16 on: April 25, 2018, 07:10:05 AM »
Nice job  :thumb:
With the generator bracket on this engine "Beefed up" let's hope the damage causing vibration is curtailed and that the erosion to the front mating surface is relieved. Time, of course, will tell.
'69 Manky V700
« Reply #17 on: April 25, 2018, 08:43:12 AM »
Exactly. If vibration is destroying the aluminum shim, then parts are still moving around that shouldn't be.
Offline mcdammitt
  • Do like the Hindu, the best you kin do
« Reply #18 on: April 27, 2018, 08:15:16 PM »
Charlie, that was a beautiful build.
'03 EV w/Champion sidecar
'73 Eldo
'69 Triumph Bonney
'47 Nimbus
'72 Norton Commando
'81 Laverda 1200
« Reply #19 on: April 27, 2018, 09:45:03 PM »
Thanks. Hoping to eventually make my own V700 drivetrain just as nice.
Offline Rick4003
« Reply #20 on: May 21, 2018, 08:50:07 PM »
Hi Charlie, just looked through your album again, looks really nice. Well done.
Every time I see the generator arrangement I think about, how do you adjust the belt tension? Do you shim the two sides of the bottom pulley?
« Reply #21 on: May 21, 2018, 09:09:49 PM »
Yes, there are shims that go between the two halves of the bottom pulley.
Offline m13
« Reply #22 on: May 22, 2018, 08:15:08 AM »
 I want to thank Charlie for this superb rebuild of my V700. As you all can see from his photo diary of his work that he made many improvements and his attention to tiny detail is amazing. He kept those elements that were in excellent condition and replaced and/or improved upon the parts to make this a solid stock drivetrain. On my end? Nearing the point of getting this beauty out of the basement and on to the highway. Charlie rocks!
'69 Manky V700
« Reply #23 on: May 22, 2018, 10:36:03 AM »
Great stuff a usual, thanks for posting  :bow: :bow: :bow:
Offline m13
« Reply #24 on: November 10, 2018, 03:35:11 PM »
Well she's been sitting idle in my basement for quite a while. Once in a blue moon I'd add a cable or some minor last minute detail, but hasn't been a high priority since last post. Today I muscled her up the basement stairs and to the garage. Ready to add some petrol to the tank and fire her up! Best riding season, no bugs, no sweaty helmet, just have to watch for ice later on.
'69 Manky V700
Offline Don G
« Reply #25 on: November 15, 2018, 10:30:56 AM »
BEAUTY! :thumb: DonG
Pizza Guzzi
« Reply #26 on: December 03, 2018, 08:17:16 PM »
Great photos ! There's something so satisfying about the before and after photos of various parts then seeing it all reassembled and knowing the end result is vastly superior to when it came off the production line.
Glenn.
Offline m13
« Reply #27 on: May 14, 2019, 11:43:21 AM »
Though, it's Charlie's thread,..it's my bike and to follow-up,..and to conclude..
After the first start up once I brought her out of my basement, the bike ran poorly and so with return to Charlie for "sorting"( I couldn't figure it out myself)
 he found the new condenser to be defective, so Now,..starts easy, runs great and she's being gradually broken in back home in Southern Maryland.
Again I'm fortunate to have such a great mechanic to have helped to bring this old Gal back to life, Thanks, Charlie!
'69 Manky V700
Offline Mads
« Reply #28 on: June 02, 2019, 03:42:39 AM »
Congrats on beautyful build. Great with The reference photo album. Now get it out, break it in and enjoy it! Well earned.
I'm beefing up my dynamo bracket as well, broke it and limped 400 km back to Milan. Sounded like a hammerdrill.. But no serious damage done!
I just wondered if You (Charlie ) used a square to determine the thickness of the inlay between dynamo and block or just allowed the alu strip to wedge down with the tightening of the saddle bracket?
And thanks for the good advice on my gearbox rebuild, held up and shifted good all through Sardinia and Corsica.
Best regards
Mads
« Reply #29 on: June 04, 2019, 09:16:23 AM »
To determine the thickness needed, I use "feeler gauges" slipped in between the generator and saddle of the engine case.
