Demar, Please take your multimeter on Ohms and poke the two probes into the jar 1/2" apart and tell us what it reads.ThanksRoy
" Do not use anything to coat the surface between the battery terminal and battery lead. This will inhibit current flow and cause additional electrical symptom problems. If you absolutely have to use something, make sure you apply it only after the connection has been made and terminal is tightly connected.� Currently we advise against it."
Be sure to measure the resistance when it arrives.Between two probes 1/2" apart
with my 2009 stelvio I had that after a year. I cleaned it, put a bit normal grease on, nothing special, and now the same battery still is working, and hasn't given any problem. I Don't tender it over winter and is still going strong. No sweat!
