X9 Megacycle is more streetable than X10 may need some mods. Lot's of info out there. Have him flow your heads first.
Big Block are mostly the same size for cams. I put a X9 in a Griso w/stock stuff. I know of a X10 in a Scura that is a monster above 6K rpm, he did his own flowing. Mike Rich did the Griso heads, nice work. There are others familiar w/Guzzi heads, I think Ace Mallot was doing some of that.I think doing the heads is what makes it all work.
Guzzisteve, Griso is much closer in setup to V11 then 850T or 1000SP. From what I know Moto Guzzi used their experience and expertise and made hotter camshaft for V11 sport/Le Mans/Scura/Ballabio.So, by you saying that you installed X9 is a big plus. So, if I understand you correctly you got Megacycle 620x9 camshaft. Did it go right in?Do you personally know the owner of the Scura with X10 that you are describing as a monster?If you do, then it would be awesome if Scura owner chimes in.ThanksVlad
No issues w/instalation. Heads on the G were done by Mike Rich and flowed almost twice the CFM, valves were sunk, heads cut, lots of compression. I checked all clearances. Edit: Looked up notes, Griso has a X10 in it.Here is the Scura--http://racingsportservices.com/You could call Chris, he does lot's of race engines.
X-10 makes more sense. I'd think a X-9 wouldn't make that big of a difference as it's pretty mild ( although much better than the stock lawnmower cam ).
So, if one would want to stay close to OEM but have better camshaft then X9 is fine.
