Author Topic: EV fuel line replacement help!  (Read 3971 times)
Offline flower_king001
« on: December 27, 2017, 10:17:10 PM »
Hi-
Started the EV this morning and noticed a leak. Seems to me coming from one of the fuel lines going to the driver side injector. Removed the assembly from the pressure regulator(single line) to the Y and then split into 2 on their way to the injectors. Went to Nappa and purchased 5/16 (7.9mm) hose as someone replaced it years ago with the same Gates. Got some new screw on smooth inner clamps and proceeded to make a new Y assembly. No matter how hard I try (even purchased smaller clamps) I could not get the hose not to turn on the junction. I found this brilliant article by Patrick Hayes:
http://www.guzzipower.com/FI-HoseReplace-Pat_H.html
Question...does anyone know of a good source for the hose and clamps that I need?
Would this kit work from Euro Motoelectircs?
http://www.euromotoelectrics.com/product-p/fp-hoseextinj.htm
What I thought was going to be an easy fix today turned into a project.  :violent1:
Thanks, Brian
« Last Edit: December 27, 2017, 10:35:43 PM by flower_king001 »
1971 BMW R90/5
1998 Moto Guzzi 1100 EV
2005 BMW 1200 RT
2007 BMW 1200 GS
2007 Moto Guzzi Breva 1100
Offline pehayes
Re: EV fuel line replacement help!
« Reply #1 on: December 27, 2017, 10:51:25 PM »
So, why not run down to your local BMW car dealership?
« Reply #2 on: December 27, 2017, 10:56:14 PM »
Local BMW dealer from here is about 85 miles one way..
This kit should do the trick or?
Thanks, Brian
BTW, brilliant tech article
1971 BMW R90/5
2005 BMW 1200 RT
2007 BMW 1200 GS
Offline pehayes
« Reply #3 on: December 27, 2017, 11:08:47 PM »
Should work, but so should the ones you already purchased.  I don't like those clamps provided by EME.
This is what the BMW clamp looks like.  Nice, small hex head for tightening with a nutdriver.. 4 or 5 mm I think.
Online n3303j
  • Ron Cichowski
« Reply #4 on: December 27, 2017, 11:26:17 PM »
https://tinyurl.com/y74ztf8m
Worked fine on my EV. Has since worked fine on a lot of other hoses. Solid tool for short money.
'98 MG V11 EV
'96 URAL SPORTSMAN
'77 MG 850T3 FB
« Reply #5 on: December 27, 2017, 11:34:10 PM »
Hi Ron-
 Did you use these crimp on clamps just on the Y junction? How about where the hose connects to the injector?
Thanks-Brian
1971 BMW R90/5
2005 BMW 1200 RT
2007 BMW 1200 GS
Online n3303j
  • Ron Cichowski
« Reply #6 on: December 28, 2017, 05:28:23 AM »
I just build the hose assemblies with the permanent clamps. I want to be able to remove assemblies in case field maintenance is required.
'98 MG V11 EV
'96 URAL SPORTSMAN
'77 MG 850T3 FB
Offline antmanbee
« Reply #7 on: December 28, 2017, 06:16:14 AM »
You can use any hose that has the SAE  J30R9 rating that is the right diameter. I think I used either Gates or Dayco.
Use high quality clamps designed for FI or the crimp ons.
I used these,
https://smile.amazon.com/gp/product/B00OL26AW0/ref=pe_852110_211764720_em_1p_0_ti
« Reply #8 on: December 28, 2017, 08:07:13 AM »
Thanks for all your info...I just order a dozen of the BMW clamps and some 7.5 X 13.5 smooth rubber outside w/ inside braiding FI hose. The Gates and Dayco 5/16" just doesn't fit snug enough.
-Brian
1971 BMW R90/5
2005 BMW 1200 RT
2007 BMW 1200 GS
« Reply #9 on: December 28, 2017, 08:53:59 AM »
thanks...ordered the kit and will use ear clamps on the Y junction. The line connecting to the regulator and fuel injectors will be BMW clamps.
1971 BMW R90/5
2005 BMW 1200 RT
2007 BMW 1200 GS
« Reply #10 on: January 07, 2018, 12:47:40 PM »
update:
 I ended up getting the BMW smooth inner high pressure hose clamps and replaced the original 7.9 mm (5/16") hose with 7.5mm which is a much tighter fit. Took the bike out for a quick jaunt and all seems well. thanks for everyone's input here.
-Brian
« Last Edit: January 07, 2018, 03:00:11 PM by flower_king001 »
1971 BMW R90/5
2005 BMW 1200 RT
2007 BMW 1200 GS
« Reply #11 on: January 07, 2018, 01:27:36 PM »
Just a tip -- I sometimes deliberately get smaller hose for these particular fittings and install them with a heat gun.  As the hose cools it shrinks onto the barbs.  I forgot to put a hose clamp on an injector the last time I did the hose.  I noticed and corrected it ~12k miles later because the clamp was missing, not because it was leaking.  Now I'm not suggesting that you skip the clamp part of the installation.  I'm just saying that a "sloppy" 1/4" hose will fit a sloppy 8mm barb with the help of a little heat.
Offline JoeB
« Reply #12 on: January 07, 2018, 05:28:52 PM »
Learned (the hard way) that when one part goes bad to check, heck replace, the entire fuel system hoses. YMMV
