partsneeded
Topic: partsneeded (Read 1868 times)
John A
No way to slow down...
partsneeded
December 30, 2017, 04:03:20 PM »
I have an old General Electric motor, 1/4 hp model 27468, type sa, Frame147, FormDB that I need brushers for. they are cylindrical, about 5/16" diameter. this motor apparently predates the modern numbering system and I'm stuck , cannot find any info on this motor. Anybody have any ideas?
pehayes
Re: partsneeded
Reply #1 on:
December 30, 2017, 04:11:32 PM »
I know some old equipment people. Pics might help.
Lumpy Idle
Gaggle Mentor
Re: partsneeded
Reply #2 on:
December 30, 2017, 04:27:09 PM »
i'd give these guys a call. while none of their g.e. brush pics look like round brushes (hard to tell from some of the pics though) they may be able to lead you in the right direction. perhaps you can swap out the entire brush cage for a more contemporary square or rectangular style and then use more standard brushes from that point forward. just a guess. good luck.
http://www.repcoinc.com/brushes/series.asp?curpage=1&brushNumber=&cb_thickness=&cb_material_type=&cb_width=&cb_length=&idManufacturer=1&sortField=&asdf=10&pagename=Carbon_Brushes_General_Electric_GE&pageSize=9999
'97 1100Sporti
'76 850T3
"You cannot successfully determine beforehand which side of the bread to butter."
--- Anonymous
rodekyll
Not my real name
Re: partsneeded
Reply #3 on:
December 30, 2017, 04:34:18 PM »
I have rebrushed many motors using the generic brushes in the parts array at True Value Hdwre, often for ~$1.00. Sometimes you have to file them to fit, but carbon is carbon. If it slides in the bore, takes a spring, and the pigtail connects, it should work.
RinkRat II
Lake Powell AZ
Re: partsneeded
Reply #4 on:
December 30, 2017, 04:35:20 PM »
My local Ace hardware carries a good assortment of universal brushes. If all else fails you could make your own
https://www.ebay.com/itm/2-MICRO-PROJECTOR-CARBON-ARC-RODS-8-1-MM-6-IN-LONG-MAGIC-LANTERN-184/332462268939?hash=item4d684ba20b:g:okEAAOSw~RVaEpQy
8.1mm a little bigger than 5/16 but could be lathed or filed to fit. My $.02
Paul B
John A
Re: partsneeded
Reply #5 on:
December 30, 2017, 06:54:28 PM »
John A
Re: partsneeded
Reply #6 on:
January 02, 2018, 11:46:09 AM »
Lumpy idle is the winner! I called Repco but they had a minimum order, they told me to go to Eurtinelectric.com. I looked at their catalog and was undecided so I called Advance Carbon, another place Repco told me about. They had parts catalogs from the 1920's and they gave me the correct part number but they were out of stock. so back to Eurtin electric and brushes are on the way. I looked thru my stash of brushes and didn't have anything remotely similar or would have made some, I was getting ready to order some round carbon like Rikrat suggested. Thanks Guys!
partsneeded
