Breather Box
Topic: Breather Box (Read 1183 times)
blusmith
New Egg
Breather Box
January 01, 2018, 01:15:43 PM »
Can someone help me to connect an after market Le Mans type breather box for a small block twin (V75) I have rebuilt this crashed bike and no air box came with the bike The breather box has five pipes a pair of small tubes at the top and three larger ons at the base one of which has a one way valve in it
Cheers Chris
Antietam Classic Cycle
Happily stuck in the past.
Re: Breather Box
Reply #1 on:
January 01, 2018, 02:20:05 PM »
Instead of trying to adapt a breather box meant for the early "big-block" Guzzis, why not use the correct one for your (small-block) bike?
http://www.harpermoto.com/16-housing.html
guzzisteve
"Just Ride It"
Re: Breather Box
Reply #2 on:
January 01, 2018, 03:03:10 PM »
If you're bound & determined to do it. The Small Block only vents at valve cover , that would go to the 2 line spigot on top. Drain to back of your oil pan goes to small pipe on bottom. Large pipe on bottom cap, it is for a pvc pressure system. Angle pipe on bottom should let extra pressure to outside air.
Try it it may work, if you have the parts already.
Breather Box
