Author Topic: 73 Eldorado and Franken Guzzi LeMans  (Read 13119 times)
Offline 73eldorado
  • Theres a fine line between tough and stupid
Re: 73 Eldorado and Franken Guzzi LeMans
« Reply #30 on: January 09, 2018, 08:29:14 PM »
Hi Turin, the racer started life as a 1981 Lemans II, after riding it for 80000 km (50000 miles) I decided to turn it into a track bike. In stock form it was awful, our track was so rough it would tank slappers and the forks were way to flexible. I had a bunch of parts off of GSXR 750 race bikes and parts from a TLR 1000 race bike. First thing I did was graft on a complete front end by fabricating a new steering head but it looked stupid raked out like a chopper. So I jigged up the frame and cut off the steering head and set it at 25 degrees. Now it looked modern, it needed modern suspension in the rear and I had a donor Ohlins shock from th e TLR. So I cut the rear section off frame off and modified the swing arm for a single shock. The fairing is from the original 750 Ducati, tail section from a RC 30. I wanted radial tires so the meant that the engine had to be moved over so that the swing arm could be moved over and then notched for more clearance. Engine makes 85 hp and it�s a 950 with a big cam, sorry I can�t remember the specs it�s been a while. The valves had to be sunk quite deep into the heads to prevent hitting each other on overlap, it�s preety stout and required a new exhaust because the lafranconi exhaust was ground right through because of ground clearance issues. I built a 2 into 1 exhaust that everyone says doesn�t work and the first couple had huge flat spots in the fueling but my last try had perfect fueling and sounds awesome. LOUD! It starts on a roller system I build which uses my truck to power it, I butchered the crap out of the flywheel so that when you let of the gas it actually slows down, the stock setup would feel like it sped up when you let off the gas. I�m actually going to turn it back into a street legal bike and make it preety, race bikes get a little ugly but chrome don�t get you home. It goes on and on, the amount of stuff you have to change and figure out when you get in this deep, but it was good fun and didnt head shake any more and never dragged parts on the track. Best of all it was unique!
1973 Eldorado
1981 Lemans
2006 Hayabusa
1978 Suzuki GS 1000
1997 Honda XR400
Offline Bucky
« Reply #31 on: January 09, 2018, 08:36:41 PM »
 I gots one word for you, Al......Craftsman!
Awesome build!!!
1973 Eldorado
Offline Turin
« Reply #32 on: January 10, 2018, 08:45:57 PM »
Good stuff! My ex-racer is running a X-7 (norriss 382) cam and a 2-1 exhaust. If and when I get it finished it'll have to go on a dyno just to satisfy my curiosity.
( I did not build the engine)
1985 Sidlow Guzzi
Offline 73eldorado
« Reply #33 on: January 10, 2018, 10:32:45 PM »
Hi Turin, mine is a megacycle cam, it required different springs. The springs were from a Toyota race engine, probably a supra. I need to dig through my stuff and find the specs, I set up spring installed height etc. I think the sellers name was rich, he was into Guzzi race stuff I believe. This was probably 15 to 20 years ago. What size of a motor do you have?
1973 Eldorado
1981 Lemans
2006 Hayabusa
1978 Suzuki GS 1000
1997 Honda XR400
Offline chuck peterson
« Reply #34 on: January 11, 2018, 05:30:07 AM »
Beautiful work with an even better story!  :bike-037:
150k on Verts
750 Nevada
400f
R5 Yammie
BV250
Offline Turin
« Reply #35 on: January 11, 2018, 09:27:06 AM »
My engine is a big valve 1082 (78mm stroke 94mm bore. There are pics in the build section.
1985 Sidlow Guzzi
Offline 73eldorado
« Reply #36 on: January 11, 2018, 10:41:39 AM »
Looks like a fun project, sounds like it will have a monster engine! I’m hoping to start working on Franken Guzzi in the near future, I will post it in the build section, just looking at yours gets me revved up. I’m 60 years old and my wife says when are you going to grow up! My response is “ Never, it’s overrated and no fun!!
1973 Eldorado
1981 Lemans
2006 Hayabusa
1978 Suzuki GS 1000
1997 Honda XR400
« Reply #37 on: January 11, 2018, 12:06:07 PM »
Stay cleverly disguised as a responsible adult!  :cool:
