motoguzzi navada 750 1994 white smook
Topic: motoguzzi navada 750 1994 white smook (Read 1900 times)
zari
New Egg
January 12, 2018, 07:27:58 AM »
hello
after warm up chack Compression with guage in engine both side 165 psi look like EVERY THINK ok!!!. but what is the reason for white smooking and wet spark plug right side only
rings worn out ? or maybe valve rubber gasket ? or head gasket ?
help please !!!!! :Beating_A_Dead_Hors
e_by_liviu
Last Edit: January 12, 2018, 07:35:33 AM by zari
live motoguzzi for ever
timonbik
Gaggle Mentor
Re: motoguzzi navada 750 1994 white smook
Reply #1 on:
January 12, 2018, 07:42:49 AM »
Are you sure it is firing properly on both sides. If the plug is wet, thinking bad plug, spark plug cap or lead.
2008 BREVA 750
2020 V85TT ADV rosso
2016 APRILIA SHIVER 750
2013 VICTORY JUDGE CUSTOM
2013 VICTORY XR CLASSIC
2006 VICTORY V92TC
guzzisteve
"Just Ride It"
Reply #2 on:
January 12, 2018, 09:08:41 AM »
I would check the carb float bowls for water. Impurities in your fuel also. Maybe junk in your airbox,
Where are you from?
Oil would be blue smoke.
Chuck in Indiana
Reply #3 on:
January 12, 2018, 09:26:19 AM »
Like Steve says, white smoke is water. It can be nothing more than condensation in the exhaust system burning off.
