don't know but why aren't you looking at a Subaru?the 2008 Forester I got came from Kansas and it's great.
It appears that an Altima uses an H11 low beam bulb, with a 30 second modification, an H9 bulb plugs in.H11 bulbs are 55 watts and H9 are 65 watts, almost 20% brighter.I�ve done this to several vehicles and it makes a huge difference.
Considering purchasing a 2015 Altima SL. Doing some searches on several Nissan forums one serious complaint came up on all the forums. That was how poor the headlights are on the low setting. I live in the country and this could be significant. Anyone here own one or know anything about this possible concern?GliderJohn
Go for a test drive after dark before agreeing to buy.
Altimas are good cars. I like Accords myself but nothing wrong with a Nissan. Don't know about the headlights.
I have read that Subarus have had problems with blown head gaskets, above 80k miles.Has that issue been resolved, or is it still a problem? I have read that the block/head interface doesnt have enough metal for a proper seal/bad design.Rick.
From Lowryter: I have owned four Accords and my current one is a 2003. Have liked them all and have had minimal problems but for whatever reasons currently the Accords are running about 2-4K higher for equivalent years, miles and features and the Camrys are falling in between. The Nissan has more power and the Bose stereo. GliderJohn
they all hold up pretty well if maintainedmy only knock on nissan is they use those cvt trans on everything and we sell a lot of nissan transmissions.
On another note, the newer Subies, 2012 and up 2.0, and somewhere in that time frame the 2.5, went to a chain to drive the cams, with the exception of the engine in the WRX, although that may have changed by now too. So there is now 0 maintenance on a cam belt.John Henry
it seem like a common thing to replace the head gaskets at the same time as the timing belt at around 100k, mine was supposedly done at 127k.. but yeah I've heard a lot about that problem with Subi's.
Not on my frontier.
cvt's are on the FWD cars only. and we sell a lot of frontier/pathfinder transmissions but that's due to bad radiators
Do you know if bad radiators also affects the automatic transmission in a 350Z ?, I imagine what you refer to is the ATF cooler inside the radiator leaks, and puts coolant in the transmission?Rick.
