Being that it's a lot newer than mine, you probably already have the feature, but I installed rubber bushes on BOTH ends of the reaction rod on my '07, it does soften out the on/off transition a fair bit.Also I have a habit of "cracking" the clutch in the lower gears ever so slightly to give some disconnect between the gearbox and bevelbox.I didn't know I was doing it 'till I saw some video footage.
The more forgiving silentbloc bushes have been standard since about 2009-10.Pete
Hmmmm..... I'll have to add that to my list of stuff to refresh as the 2008 Norge enters major service mode this spring... (fall to you southern types)
Huzo, are the rubber bushes aftermarket, and softer than the OEM bushes on the reaction rod?Bob
Have you done a camchain yet ?
Definitely more "silky" in the seat of the pants feeling when on/off throttle.I can't say if they're softer or not.Paul at Corsa in London fitted the front one while I was taking a leak !
No, haven't opened the engine for anything at all. I'm working with a very good mechanic for all the stuff I can't do myself, and he's going to check everything out while the clutch is being done.
Which bushings are these that you speak of Huzo? Part # perhaps?Thanks in advance!
Aha...Ok...was trying to determine what you meant by reaction rod...crystal clear now.Thanks!
Made a leap of faith ('cause I'm still not sure about the weight). Thanks to everyone who provided advice and encouragement.
Is this the 2015? Nice.Pete
I'll do my best to follow that excellent advice.
Got the bike all checked out and did the 6k service a little early. It's as sweet as I thought.Took the bags off, turned the heated grips on, and took her out for a ride this morning. Brrrrrrrr! Started at 38 F and got as low as 34. May have to invest in some heated gear.What a lovely ride though. Solid handling that's surprisingly light/nimble. At least it's surprising me. Excellent comfort so far though an admittedly short ride; stopped for coffee after an hour. Windscreen has a bit of buffetting even at its highest setting but I can easily duck down into a totally smooth pocket. May/may not try other options.It's a good day.
I wouldn't mind the bars coming back toward me a little. Short arms or more lean than I'm used to.
I was off enjoying a bit of the Youtube video of your 2017 trip. Gotta love Brothers in Arms, eh?Yeah, I'd be interested to know your setup. If you've already posted about it, happy to look it up.
