Have prop started a Cessna 182 a number of times, makes me very nervous.GliderJohn
Would a airplane count? https://m.youtube.com/watch?v=3zXkVQnVmuo
The starter button was on the floor on old cars, because when you pushed it, a big metal bar actually went across from battery positive to the starter. There wasn't even a relay. For all I know, there might not even have been a solenoid .... !No "startus interruptus", no batteries failing in remotes ....Lannis
For GM there was no actual solenoid, all mechanical action hooked to a switch on the starter motor..And then for some cars was a dash mounted starter button like early 50's GM......Hey, nothing more reliable than a kick start bike and many of them don't need a battery, right
Heck, prop-starting a Fox .35 makes ME nervous .... !Lannis
On the old B52's and KC135's with PW J57's they had a fitting for a starter cartridge which consisted of 5 lbs of black powder to supply high volume, low pressure gas to start them. Used them on alert and if we went to Africa or anywhere else that didn't have a blower unit. Lots of smoke!
The British used that system on some of their WW2 piston engine planes due to lack of materials for electric starters....In the film with Jimmy Stewart where the planes crashed in the desert and the survivors rebuilt it, he uses the last cartridge to start the thing..
Reason is simple, and AWESOME!You just have to carry the damn thing (in a pocket, a bag, wherever), then walk up, open the door, sit down, press a button.It's fantastic. I was so pissed to go BACK to a regular key with my Wrangler two years ago.
^^^ :1: ^^^What I want to know is if You can still wack it with a wrench to get it to turn over?
Some of my junk has a "touch" start.... https://www.flickr.com/photos/75289626@N08/15262178918/
Just ran into this with a friends Honda. Went on a trip, I am driving. She gets out and goes in the store. She has the fob, and we don't think about it. I drive away to the parking garage, with a dog in the car. Park, and shut off the car. Oops, now I am screwed. Dog in the car, hot sun, can't roll down the windows, and can't start the car. The car is now a massive piece of anchor. I can't leave the car because the dog is in it. What a pain in the rear. Eventually she finds us. It is my understanding that there are a number of deaths now related to people getting out of a running push button car, and later they die from CO poisoning, with the engine continuing to run in the attached garage.
My wife's 2017 Lincoln MKC has push button start AND push button gear selection. I still can't get used to the gear selector. The car also has something else that annoys me......Ford's Start-Stop technology. Every time you come to a full stop the car engine shuts off. As soon as you release the brake the engine fires back to life......it is almost instantaneous. The more annoying part is that it cannot be permanently disabled. You can disable the function for the current driving session with a button on the dash but it will reset when you turn the car off then on again. From what I've read, all of Fords new vehicles have this technology, including the trucks. Glad I bought my truck in 2013....pre-aluminum bodies and start-stop insanity.
On the stop start cars. Is it the starter that re-starts the engine or something to do with the transmission re-starting the engine?Maybe it's a hybrid that uses the transmission?Tom
Would seem to me that the stop - start technology would cause premature wear on the starter and related items. GliderJohn
