Author Topic: Stelvio display says enter code  (Read 2310 times)
Offline Johncolleary
« on: February 05, 2018, 06:11:59 PM »
I did a search but did not find this....
Question: Randomly when I turn on the key a message comes up and says "Enter Code" Usually if I turn the key off and right back on everything boots as normal and bike starts no issues.  It just scares me when I see this.  I have a code set but have not tried entering it at that time to see what happens I will next time if I'm home it makes me nervous when this happens a couple of thousand miles from home.
Any ideas why it would happen randomly?
2013 Stelvio NTX
2014 Triumph Tiger 800
2024 Honda Transalp
2023 Kawasaki KLX300
Re: Stelvio display says enter code
« Reply #1 on: February 05, 2018, 07:07:01 PM »
The secure key, or the antenna to read the key code, is likely failing.
I would clean the antenna connectors with deoxit or such first.
« Reply #2 on: February 05, 2018, 07:36:37 PM »
is that on the key or in key slot
2013 Stelvio NTX
2024 Honda Transalp
Offline ITSec
« Reply #3 on: February 05, 2018, 07:58:24 PM »
The antenna is typically a collar around the key barrel, with a small lead to a nearby connector.
ITSecurity
2013 Stelvio NTX - Copper
2008 Norge GT - Silver
I am but mad north-northwest!
« Reply #4 on: February 05, 2018, 08:09:19 PM »
Thanks Ill check it out
2013 Stelvio NTX
2024 Honda Transalp
jlburgess
« Reply #5 on: February 06, 2018, 11:29:18 AM »
That happened to me when I used the spare key.  It apparently isn't equipped with the chip and fancy MG logo.
Offline Darren Williams
  • Finally got me a Griso!
« Reply #6 on: February 06, 2018, 12:10:11 PM »
The positive in this is that Moto Guzzi was smart enough to program in an over ride (entering code) if the immobilizer system fails. On my BMW, if the immobilizer fails you're stuck and will have to haul the bike to a dealer (bringing a big wad of cash). :rolleyes:
Offline ITSec
« Reply #7 on: February 06, 2018, 12:15:36 PM »
The spare key DOES have a chip, just not the decorative plate. If you bought your bike second hand, it's possible your spare was replaced at some point and the new one not properly programmed.
ITSecurity
