Author Topic: 1998EV rides like crap  (Read 12323 times)
Online rodekyll
Re: 1998EV rides like crap
« Reply #60 on: February 09, 2018, 03:00:06 AM »
Over tight steering head ?!? For the love of gawd, there is literally no end play in a properly setup steering head. If it was too tight then they have certainly Brinnelled the races and need to be replaced.
Just my two cents. The list of changes you listed was huge and it is hard to tell from my arm chair where the handling went south.
Skippy
It depends on the type of steering head.  On the guzzi big block the free play is in the order of 0.004 - 0.006-ish".  Nobody can accurately measure that on a fully assembled, angled vertical steering post, so we do it by feel.
Offline Strom
    • Moto Guzzi Slovenia forum
« Reply #61 on: February 09, 2018, 04:40:10 AM »
Yep... handling just went south slowly during the years, but for the past few.. I have been searching for a reason and slowly replacing stuff that needed replacing anyway and tried to get a better ride.
I talked to a friend a few days ago... this poor handling seems a pretty common issue in Calis around here. At around 60k miles with some serious riding people just give up and sell them, or take them apart to cafe them, but give up and they gather dust in corners. Heard of 3 such cases (besides mine). The others I know of do not have that many miles.
...should have bought a blue/blue 98EV from a neighbor last year... 6k miles from new, one owner. :/
Since everyone has their list of bikes in their sig... and it seems useful, here we go:
1979 Yamaha XS 1100
1984 Moto Guzzi V35 II
1998 Moto Guzzi California EV
2001 Aprilia RST1000 Futura
« Reply #62 on: February 09, 2018, 08:17:51 AM »
Sorry, I'm not buying that.. the Tonti frame has been noted for good handling from it's inception. I know of many with over 100K miles that are still fine.
Online rodekyll
« Reply #63 on: February 09, 2018, 12:49:42 PM »
If everyone's poor handling is specific to your area (and it must be -- mine handle fine), I'd find out who everyone's mechanic is and go somewhere else.
Offline jacksonracingcomau
« Reply #64 on: February 09, 2018, 04:26:47 PM »
I’m pretty certain factory addressed this before op bike was made but the weak link after suspension in early Tonti frame design was the pissy tin frame suport frame (under battery).
Every hard ridden one & maybe even every single one that I laid hands on in 80 s had cracked
This is engine mount so is important, easily fixed with alloy plate as most have been
I know factory fixed this with a cast alloy bolt on and through bolt to frame, but don’t know year of fix.
Other than that I agree with Chuck & RK, nothing to wear out only crashing will bend them.
Wonder if all the handling expired ones get sold cheap, be interesting to find common denominator,
« Reply #65 on: February 09, 2018, 04:38:39 PM »
 Mine has 140K miles and still handles well , in fact the idea that at 60K miles the handling goes bad is ludicrous . Something hasn't been maintained or is worn out . Shocks , neck bearings , swing arm bearings , something .
« Reply #66 on: February 09, 2018, 05:07:42 PM »
Find a better mechanic.
« Reply #67 on: February 09, 2018, 05:08:48 PM »
 Yeah , my guy is kind of a Richard  :laugh:
Offline Strom
« Reply #68 on: February 10, 2018, 02:35:11 PM »
Haha :D
Anyway, the battery tray plate thingie looked OK. A bit corroded, so I cleaned it up and re-sprayed it.
Here is a pic of the bottom side of the gearbox with modified H pipe and subframe connection. Had to clear external rear facing oil filter. Also a pic of the footpeg/exhaust holder bracket... cracked on the bottom.
1979 Yamaha XS 1100
Offline geoff in almonte
« Reply #69 on: February 11, 2018, 06:23:38 AM »
A more definitive description of the symptoms would help.
Ya gotta obey the laws of physics.  Check out the following article.
file:///C:/Users/Geoff%20Helmes/AppData/Local/Microsoft/Windows/INetCache/IE/BZCD7UJC/Suspension101eBook.pdf
G
Midnight bugs taste best
« Reply #70 on: February 11, 2018, 07:03:32 AM »
Offline Strom
« Reply #71 on: February 11, 2018, 02:33:56 PM »
oops - try this....G
http://www.totalcontroltraining.net/Suspension101eBook.pdf
Awesome! Static sag was set, I played with compression and preload front and rebound rear... Will try higher tire pressure and set suspension by this guide. :)
Today I was busy with the dash... stupid white vaguelias kept on dying, so I replaced everything with a cheap chinese speedo/rev counter, that was utterly useless. Finally got another job and could afford a speedhut set. :P
1979 Yamaha XS 1100
