Air filter box LM 1000?? ....Solved
Topic: Air filter box LM 1000?? ....Solved (Read 1320 times)
RoyRogers
Hatchling
February 18, 2018, 11:42:31 AM »
Take a look at the pictures..hoses from under the air filter box .
I have mounted one hose her, (small one in the middle of the last picture), is it correct?
The second one, same dimension, but shorter are going... where? Gearbox?
I'am all ear
Last Edit: February 18, 2018, 12:32:29 PM by RoyRogers
Regards from Norway, Roy
1972 850GT
1986 LM IV
1991 BMW K1 with Sidecar
1984 Citroen DSpecial
SED
Re: Air filter box LM 1000??
Reply #1 on:
February 18, 2018, 12:17:25 PM »
If it's the same as a 1983 LMIII it's a draft tube.
One end from frame, Y-fitting under airbox, and other side of Y down next to transmission.
Hope this helps!
1983 LeMans III
1981 Monza
1947 Ariel Red Hunter
1939 Ariel Red Hunter
1937 Guzzi GTV
RoyRogers
Hatchling
Reply #2 on:
February 18, 2018, 12:31:00 PM »
Thank you very much.
Problem ( or question, solved)
1972 850GT
1986 LM IV
