Author Topic: Sport 1100 + 1100i actual weights  (Read 2877 times)
Offline Kristian
« on: February 21, 2018, 01:52:01 PM »
Lads,
I've collected a pile of English and German-language Sport 1100 reviews, and thought the following wet weights (actual measurements) might be interesting:
Sport 1100:  505 Lbs. (229.5 Kg.)
Sport 1100i: 538 Lbs. (244.5 Kg.)
Best,
Kristian
Seattle
Online Tom
Re: Sport 1100 + 1100i actual weights
« Reply #1 on: February 21, 2018, 03:17:31 PM »
The FI stuff adds the weight vs. the carbs.  '97 model vs. '95/96
From the Deep Deep South out in left field.  There are no stupid questions.  There are however stupid people asking questions.  🤣, this includes me.  😉
Offline Alpo
« Reply #2 on: February 21, 2018, 06:30:02 PM »
Fuel pump, fuel filter, a couple of high pressure lines, I would think the throttle bodies would be a wash, or even save a few grams over carbs full of fuel... I'm not seeing the numbers add up. Am I missing something? Or are there other differences than just the injection system? Someone enlighten me.
« Last Edit: February 21, 2018, 06:33:02 PM by Alpo »
Jackal Cafe'     Skorpion Tour
1100 Sport     Transalp
Lario              CB1
V 700             V85TT Adventure
« Reply #3 on: February 21, 2018, 06:53:02 PM »
Wheels, the cush drive plate is not light.
Offline Tusayan
« Reply #4 on: February 21, 2018, 06:59:50 PM »
Yes, there are differences other than the EFI system... The cush drive is definitely a added weight for the Sporti, but the Brembo wheels on the EFI bike are possibly lighter (?)  The same may also be true for the single AGM battery compared with two 6V conventional batteries used on the carburated bike.   Are upside down WP forks heavier than old style Marzocchi forks?
33 lbs difference seems like a lot to me, either way.
Offline tazio
« Reply #5 on: February 21, 2018, 07:06:11 PM »
Cush drive in '97 and up 1100 sporti.
Also, Helical gears in gear case(Sometime into 1997 after a particular serial number on box as early '97 were straight).
With torque through helical gears, axial loads need a strong transmission case and shafts, this may add weight.
2015 Moto-Guzzi GRiSO
1967 Kawasaki 650 W2TT
1966 Triumph Bonneville
Offline Kristian
« Reply #6 on: February 21, 2018, 07:26:38 PM »
Are the cases different between the two? That would surprise me-
Also, Is have oil coolers, different triple clamps.
Kristian
Offline tazio
« Reply #7 on: February 21, 2018, 07:33:19 PM »
I just don't know that for sure (regarding cases).
Offline Kristian
« Reply #8 on: February 21, 2018, 08:06:03 PM »
Just found out, transmission cases have the same part numbers.
Offline tazio
« Reply #9 on: February 21, 2018, 08:18:10 PM »
Thanks.
Helical gear weight -vs- Straight ?
I guess it all adds up in the end.
Offline sdcr
« Reply #10 on: February 21, 2018, 08:32:33 PM »
Swing arm is different on the Fuel injected, plus, IIRC, the rear subframe was fortified. The carb models had a retrofit/ recall to add a brace for additional support for the passenger area.
Also, the FI models came with a oil cooler. Can't say how much additional weight that added though.
2000 BMW R1100 RS
1983 BMW R100
2009 Jaguar XK
Offline Devildog
« Reply #11 on: February 21, 2018, 08:43:31 PM »
I believe that was similar for the early Daytonas and the Daytona RS.
'93 Daytona 1000
'95 Sport 1100
2002 Aprilia RSV Mille R
'10 GasGas e250 FE
Online Tom
« Reply #12 on: February 22, 2018, 11:44:57 AM »
Makes sense for the Daytona 1000 to weigh less than the RS because of the same reasons for the Sports.
Offline Kristian
« Reply #13 on: February 22, 2018, 11:51:21 AM »
According to Cycle World's 1995 review, the Sport weighs 25 pounds less than the Daytona; less complicated frame cited.
Kristian
Online Tom
« Reply #14 on: February 22, 2018, 11:58:03 AM »
I'll clarify.  '93 Daytona 1000 weighs less than the '97 Daytona RS like the '95/'96 Sport weighs less than the '97 Sporti for probably the same reasons.  Okay?
Offline Kristian
« Reply #15 on: February 22, 2018, 12:47:22 PM »
There's a misunderstanding; my comment was not an argument, just stating the weight difference between Daytonas and Sport Cs.
Online Tom
« Reply #16 on: February 22, 2018, 01:44:45 PM »
No sweat.  Not an argument.   :thumb:  Concurring with you.  If we have a disagreement, there will be no question.   :tongue:
Offline Tusayan
« Reply #17 on: February 22, 2018, 02:40:17 PM »
Kristian
That's interesting because the 1995 Daytona with its heavy 4V heads, heavy wheels etc is not likely to be lighter than a 1997 injected Sport, which is supposedly 33 lbs heavier than a 1995 carb Sport.   Something doesn't add up, as I'd typically suspect when comparing measured weights from anything but a 'same day, same scale' comparison.  I'd probably want to weigh the two versions of the 1100 Sport myself, same day same scale, before being convinced of the exact weight difference between the carb and injected Sports. Literature lies  :grin:
BTW, I've owned both a Sporti and an RS, which are other than the engine almost identical and for those bikes I'd say that you definitely feel the additional weight up high on the RS but its not a major issue.  The weight difference is the heads.
« Last Edit: February 22, 2018, 02:46:11 PM by Tusayan »
Offline Kristian
« Reply #18 on: February 22, 2018, 03:35:33 PM »
Several things could account for the 7 to 10 pound additional weight of Sport i's over Daytonas; USD forks, oil cooler, heavier side plates, heavier swingarm, heavier subframe, etc.
Scales are not like dynos; they are very easy to calibrate. For example, the variance in measured weights of Sport 1100 Cs in the four different German reviews I have are all within a couple of pounds.
Offline Tusayan
« Reply #19 on: February 22, 2018, 03:58:54 PM »
The heads and timing gear on a Daytona is probably 20 lbs heavier than the equivalent parts on an 1100 Sport.
I suspect all the magazine numbers being thrown around in this thread are nonsense.
« Last Edit: February 22, 2018, 04:02:04 PM by Tusayan »
Offline Devildog
« Reply #20 on: February 22, 2018, 04:45:01 PM »
I own both, and they don't feel much different weight-wise. If the Daytona is that much heavier I can't tell it. But then I can't really feel a difference if the tanks are full or empty either.
'93 Daytona 1000
'95 Sport 1100
'10 GasGas e250 FE
Offline Murray
« Reply #21 on: February 23, 2018, 05:28:03 AM »
AGM battery compared with two 6V 12voltconventional batteries used on the carburated bike.
Just for clarification possibly nit picking but more in the interest of preventing odd rumours.
Offline Tusayan
« Reply #22 on: February 23, 2018, 09:05:57 AM »
Thanks for the correction - I had an odd recollection of two 6V batteries wired in series when in fact if is two 12v batteries in parallel.  Must've been thinking of old British cars!
