2017, V7 III Racer w/ABS.I was hugely annoyed by a very spongy front brake, from new. Near crashing once when the lever pulled to the grip and the rear brake was hardly better I took it to the dealer. He went through 2 computer controlled flush/fill cycles b4 satisfaction. I'm still not thrilled, but learned 'They're all like that', after pedaling around a new Anniversario and a Special. I had tried bleeding the brakes 3X. 2X with the lever bound to the grip over night. Which would give good braking for ~30 miles.I've had 4 bikes w/ ABS. The earliest in '93. None of them were as sloppy? as this one. I cannot feel the ABS cycling in a planned panic stop, front or rear. Or don't they do that any longer. Is it telling me I'm way too old to ride quickly? R3~
To the OP ... on a V7 iii ... maybe adjust the clutch cable around the first service (~900 miles) ... then maybe once more before 5000 miles. In other words, no big deal.As some have pointed out, you can make it too tight (and cause some issues) ... and you can ignore it and let it get to lose (and cause some issues).And if you are making an adjustment, turn the bars full right, full left, and notice the free play as it may vary (like full left might be a bit tighter than straight or full right).
2017, V7 III Racer w/ABS. I cannot feel the ABS cycling in a planned panic stop, front or rear. Or don't they do that any longer. Is it telling me I'm way too old to ride quickly? R3~
