Author Topic: Brake fluid question  (Read 5758 times)
« on: March 06, 2018, 12:08:52 PM »
Hopefully this is better than an oil or tire question ....
I have Brembo and Grimeca brake calliper and master cylinders that depending on the manuals I read call for either Dot 3 or Dot 4 fluids. Some confusion in the literature I found, especially for the Brembo components.
Can I substitute Dot 3 for Dot 4 or vice versa in a system without bleeding all the fluid out? Is Dot 4 'better' to use than Dot 3?
Jim
Re: Brake fluid question
« Reply #1 on: March 06, 2018, 12:18:51 PM »
DOT 4 has a higher boiling point than DOT 3. DOT 3 and 4 are compatible to mix.
Offline Markcarovilli
« Reply #2 on: March 06, 2018, 12:20:42 PM »
 :1:
What Charlie said..
« Reply #3 on: March 06, 2018, 12:29:58 PM »
Thanks !!
« Reply #4 on: March 06, 2018, 12:43:41 PM »
The brake fluid I've been using is "Valvoline DOT 3 & 4", pre-mixed!  :wink:
http://www.valvolinechemicals.com/sites/default/files/VALVOLINE%20Brake%20Fluid.pdf
Offline Old Jock
« Reply #5 on: March 06, 2018, 01:03:37 PM »
Far as I'm aware the DOT classifications can be confusing, I've seen DOT 4 with higher boiling points than DOT 5.1 etc:
Unless you are going to the track any 3,4 or 5.1 and up will do, they are all Glycol based and can be mixed (like oil  :evil:)
Do NOT EVER USE DOT 5.0 or just DOT 5 it's Silicone based and is not compatible with normal brake systems
Only heresay but I've heard it can turn to jelly and attack normal seals etc: so stay well clear of DOT 5 and you will be good
« Reply #6 on: March 06, 2018, 05:29:17 PM »
Thanks again, great information fellas!
Offline Two Checks
« Reply #7 on: March 07, 2018, 10:11:10 AM »
DOT 5 is okay to use per Brembo. System must be flushed of all fluid. Best time to make the switch is when replacing components. I am fixin to replace everything.
1987 1000 SPII "Il Duce' II"
Online BMCMOTO
« Reply #8 on: March 07, 2018, 02:34:03 PM »
The problem with DOT 5 silicone brake fluid is that it has a tendency to get air entrained in it that is difficult to bleed out. Never shake a bottle of silicone brake fluid, or at least let it settle for 24 hours if you do. I've used it in several applications. As someone else mentioned it sometimes leaves air voids where corrosion can occur.
 Technically all DOT fluids are compatible, thats the definition of the DOT specifications. I would not mix them regardless. If mixed the rating falls to the lowest of the mixed fluid. There are some European hydraulic brake systems that use a type of hydraulic oil, Citroen maybe?
Brian
1989 MILLE GT
2006 BREVA 750
2004 BREVA 750
1975 CONVERT
Offline Roebling3
« Reply #9 on: March 07, 2018, 05:08:14 PM »
Who wants an oil thread when you can have a brake fluid thread?
Synthetic brake fluid: Is it non-corrosive? Is it compatible with DOT 3 & 4? What about skin, eye, contact, ingestion. flammability?
Thank you all for being here.  R3~
Offline Psychopasta
« Reply #10 on: March 07, 2018, 10:13:04 PM »
Especially when Charlie nailed the answer in the first reply  :boozing:
V50 Monza 1981
Moto Guzzi V7 Stone Special 2023
Honda Goldwing 2019
Aprilia Tuareg 660 2023
Ancient A65 Bitsa, in pieces
« Reply #11 on: March 07, 2018, 10:20:14 PM »
A competent person giving the correct answer in the first reply never stopped ANY oil thread from going 5 pages in 2 days.   I don't know why a Brake Fluid thread would be any different.
First we've got to get through all of the "But I Can't Buy That At My Local Pep Boys, Can I Use Mazola Oil Instead" rap.   Then a few posts about how an oil of a different weight and spec is 2 cents a quart cheaper, and I've used it for 20,000 miles and my bike is still running, so all this 'recommendation' stuff is crap.
Then some "Sez you!" and "So's your grandmother!" and then it's just getting started good ....
Offline Roebling3
« Reply #12 on: March 08, 2018, 11:12:03 AM »
SO. The suggestion is I should have known better? That being; All brake fluid has always been synthetic? But, it has only been evident (printed on the containers), in the last several years? Begging your collective thoughts.  R3~
« Reply #13 on: March 08, 2018, 11:14:36 AM »
SO. The suggestion is I should have known better?   R3~
Not from me, since I was one of only two replies since your last post, in case it WAS me.  I was just joking around about "X threads" ....
« Reply #14 on: March 08, 2018, 11:34:01 AM »
Way to fan the flames......... :popcorn:
Mark
Rough Edge racing
« Reply #15 on: March 08, 2018, 11:54:48 AM »
 Years ago I had a 71 Datsun 510 that was seeping fluid from the clutch hydraulics....I used hydraulic jack fluid and it stopped leaking..
« Reply #16 on: March 08, 2018, 04:42:50 PM »
Mark
I can see fanning the flames of an oil or tire or Harley or moly or ethanol thread .... but does a "brake fluid" thread really have enough flames to fan?   What's next, dielectric grease?   Wait, that's not a good example ....
« Reply #17 on: March 08, 2018, 04:58:18 PM »
The brake fluid we use now with a DOT rating is all synthetic, and is either glycol-based (3 and 4) or silicone-based (5).    I don't believe that mineral oil-based brake fluid has a DOT rating, and don't think it's used in automotive applications (any more).
Offline Psychopasta
« Reply #18 on: March 08, 2018, 10:31:43 PM »
Hey Roebling, I'm sorry if my comment caused any offense. I'm just being my usual silly self.
- Pasta
V50 Monza 1981
Honda Goldwing 2019
Offline normzone
« Reply #19 on: March 08, 2018, 10:46:18 PM »
Many years ago my younger brother and a pal were riding around in the California desert and unknowingly tore a flex line to one of the rear wheel cylinders. They just kept bombing along pumping out brake fluid, until they had no brakes, then eventually rolled to a stop.
Once they figured out what happened, they rigged a patch with some fuel line and hose clamps. Having no other fluid available, they filled the system with Budweiser.
This worked well enough until the car went slower and slower and could not be convinced to move any more. The beer had foamed up and the brakes were all engaged.
So they bled foam from all the wheels and took off again. And then they had to repeat this exercise several times until they got back to roads and proper materials.
I think it would have made more sense to drink the beer and pee in the master cylinder, but I wasn't there, thank goodness.
Offline jacksonracingcomau
« Reply #20 on: March 08, 2018, 10:49:48 PM »
Not always
I buy racing brake fluid expensive and higher boiling point than any generic
But it is marked dot 3, not for highway use
Not certain but maybe dot 4 is slightly less hydroscopic, hygroscopic ?
Google probably knows
Compatible yes but wise to flush through with new every change
Offline SED
« Reply #21 on: March 08, 2018, 11:14:28 PM »
If this is correct then I have a question.  In the bad old days the rule was you did not use DOT3 in a DOT4 system because it would destroy the seals. My recollection is that DOT4 was designed for brake systems with natural rubber seals.  DOT3 fluid would cause those seals to soften and swell.  This was with old British sports cars.  Has this changed?
My answer would have been that you could use DOT4 in a DOT 3 system, but not the other way around.
1983 LeMans III
1981 Monza
1947 Ariel Red Hunter
1939 Ariel Red Hunter
1937 Guzzi GTV
Rough Edge racing
« Reply #22 on: March 09, 2018, 06:29:01 AM »
Not always
 Some DOT 4 fluid is labeled as less hydroscopic than DOT 3..........How many here ride hard enough on the street to boil DOT 3?
Offline Stevex
« Reply #23 on: March 09, 2018, 07:26:10 AM »
Brian
I have to ask...why would you shake a bottle of any brake fluid?
« Reply #24 on: March 09, 2018, 07:42:56 AM »
You overdid it at a big party the night before?   Otherwise ... ?
« Reply #25 on: March 09, 2018, 08:19:53 AM »
  And you moderators gripe about click bate threads.  Maybe it is the word oil that causes all the trouble.
 Now for my vote.  Has anyone ever used sperm oil from whales as a brake fluid?  It was once used as transmission fluid in very expensive cars with good success.
 After research I find that until the endangered specie act, spermaceti oil was used as an additive in nearly all
American cars with automatic transmissions.  This was about 1971.
« Last Edit: March 09, 2018, 08:36:19 AM by Sasquatch Jim »
Offline Psychopasta
« Reply #26 on: March 09, 2018, 09:13:43 AM »
Oh great. Now we have a sperm thread  :angry:
V50 Monza 1981
Honda Goldwing 2019
« Reply #27 on: March 09, 2018, 10:57:22 AM »
Oh come now.   That won't be so hard ....
Offline ejs
« Reply #28 on: March 09, 2018, 11:01:04 AM »
No clue about whale sperm, but I do like whale meat.  :drool::boozing:
California EV 1999
« Reply #29 on: March 09, 2018, 11:10:18 AM »
 The oil from a humpie or other whales isn't as good.  In its' day sperm oil was the highest quality available.
 And to be somewhat accurate, we can talk about it cause it is not really an oil.  It is a wax.  At least the stuff that comes out of the whales' head is.  The automotive industry used tons of it and never let on to the American public.
 They had 8 times as many tranny failures after they stopped using it until the wizards invented some high tech additives to replace it with.
« Last Edit: March 09, 2018, 11:12:48 AM by Sasquatch Jim »
