Author Topic: Pyramid Plastics Extenda Fender #058720  (Read 2827 times)
Offline AL NH
« on: March 08, 2018, 11:01:34 AM »
Hi Guys, I received the fender extention for my V7iii stone.
It does not fit the fender on the 2017 V7iii stone.
Sending back to Moto Machines. I pay the cost of shipping, they credit my card.
It may fit earlier V7 Models.
Allyn
Re: Pyramid Plastics Extenda Fender #058720
« Reply #1 on: March 08, 2018, 01:47:46 PM »
I purchased one of their huggers for my Griso, very pleased with it.
I bought it on-line direct from Pyramid Plastics UK
https://www.pyramid-plastics.co.uk/
« Last Edit: March 08, 2018, 01:52:46 PM by Kiwi_Roy »
Offline egschade
« Reply #2 on: March 08, 2018, 02:08:14 PM »
Crap - mine's being delivered tomorrow. Which one did you order? Mine says "for V7 Cafe / Classic"
Also had on my Griso - worked great and looked good.
The elder Eric in NJ
2016 V7 Stornello #394
Past Guzzis:
2018 V7 III Carbon Dark
1985 LeMans 1000
2020 V85TT Adventure
V65 SP
V7 III Stone
V50
Breva 1100
EV Touring
Offline AL NH
« Reply #3 on: March 08, 2018, 04:43:33 PM »
egschade,
Part #058720
Offline egschade
« Reply #4 on: March 21, 2018, 08:33:41 AM »
The "Classic" has a flatter profile than the Mk3. I corresponded with Pyramid and they suggested the Clubman Racer #058731 (SF if you want the stick-fit version). Looks like this version has the 'pointier' profile of our fender. Doing the exchange.
Past Guzzis:
1985 LeMans 1000
V65 SP
V7 III Stone
V50
Breva 1100
EV Touring
Offline rss29
« Reply #5 on: March 21, 2018, 12:46:33 PM »
How are you guys attaching these? I took mine off after the tape gave out and it started rubbing on the tire. I had meticulously cleaned the fender before applying but it fell off on a hot day after about a week of use.
Offline Roebling3
« Reply #6 on: March 21, 2018, 12:56:26 PM »
I'm expecting their fender extender this week. Ordered for my V7 III Racer. W/trepidations.  R3~
Offline craigclu
« Reply #7 on: March 22, 2018, 08:40:22 AM »
The one for my Norge came with some plastic rivets.  I gritted my teeth, drilled and attached with both adhesive and the rivets.  It fit well and works as expected....
He who is without oil shall cast out the first rod...”-Detonations 5:72.
Offline harrytief
« Reply #8 on: March 22, 2018, 09:41:27 AM »
Kiwi Roy
Did your extenda come as a "stick on " install or using clips?
Harry
Offline ken farr
« Reply #9 on: March 22, 2018, 10:31:51 AM »
B-1100.
Attached with ABS cement, after claeaning, roughing up the mating surfaces, and masking.
55K miles, still solid as a rock.
( knocking on wood )
kjf
ken farr
06 B1100 - click!
Fillmore, Ca.
Offline Lesman
« Reply #10 on: March 22, 2018, 11:56:20 AM »
Had one on my V Strom. Worked great as intended. I struggle to find the correct cement. Something about in Texas our plastic pipes are CVC? Texas does not permit ABS. So I over thought the whole situation. I can't remember if  I used some type of super glue  or  regular glue/primer for CVC pipes.  The Fender extenda is just one of those incredible products that should come from the factory. My Quota came with a Guzzi Fenda Extenda. The guzzi Quota setup has rivets and is actual rubber.
