Author Topic: Where to Get 10W-60 oil ?  (Read 14350 times)
Offline kirb
Re: Where to Get 10W-60 oil ?
« Reply #30 on: March 26, 2018, 01:01:48 PM »
Motocarr on ebay sells it by the case, about $13 per liter with shipping
Online Ncdan
« Reply #31 on: March 26, 2018, 02:45:58 PM »
I don’t rightly remember where this information came from but I’ve heard that the 10-60 recommended oil is due to the extra heat the closed system with an 02 sensor generates. Therefore if one is changed over to the open loop dropping the 02 sensor 20-50 motorcycle oil is fine. Any thoughts on this?
Offline webmost
  • Safety Third
    • The Sotweed Factor
« Reply #32 on: March 26, 2018, 05:09:16 PM »
Unmitigated risk aversion is the new Puritanism; complete with witch hunts funny outfits and humorless preachers thundering doom. The Deity is Safety; Satan is a Lawyer; but the object is the same: to suck the life out of life and tell you how to live it.
Offline Byrdock
« Reply #33 on: March 26, 2018, 08:49:10 PM »
Iron Pony in Ohio has Silkoene 10w-60 on closeout $4.99L $19.99 4L
https://www.ironpony.com/ipd/pl.asp/c3/Oil/c2/Oils-and-Chemicals/c1/Street-Products/closeout/True
Offline Luap McKeever
  • Owner, WildGuzzi.com
  • Administrator
    • Wildgoose Chase Moto Guzzi
« Reply #34 on: March 27, 2018, 06:53:10 AM »
2021 V85TT Centenario E5
2001 California Special
2001 California EV
2007 Honda Goldwing GL1800
« Reply #35 on: March 27, 2018, 07:04:30 AM »
Crap. I had 24 bottles in the shopping cart, then checked and it is rated SN. It's probably fine, but I'll stick with SG rated oil.
Offline kballowe
  • - Kevin the Great -
« Reply #36 on: March 27, 2018, 09:54:04 AM »
The "SG" is an obsolete classification that has been reprinted in many owners manuals for many years.  There are even some motorcycle specific oils that show "SG" on the label, if for no other reason that many owner's manuals still spec it.  Some of this has to do with wet clutch compatibility.  Much of this oil also meets the later SL/SM/SN classifications.
As an example - on the label of Amsoil MCV 20W-50 Synthetic Motorcycle oil
"JASO MA/MA-2 � API SG/SL/CF/CG-4 � ISO-L-EMA2"
I have a bottle of Genuine Yamalube that says "SG" - but then (on the side) says "Exceeds API SL"
hahahahaha then I have a bottle of Harley oil that has a picture of a Harley on the label and the grade (20W-50)
I was looking for the words "Put this in your Harley.  Trust us".   lol  - because there are no specs listed
« Last Edit: March 27, 2018, 10:06:06 AM by kballowe »
Offline Kev m
« Reply #37 on: March 27, 2018, 10:02:01 AM »
I don�t rightly remember where this information came from but I�ve heard that the 10-60 recommended oil is due to the extra heat the closed system with an 02 sensor generates. Therefore if one is changed over to the open loop dropping the 02 sensor 20-50 motorcycle oil is fine. Any thoughts on this?
FWIW - even the tech bulletin that came out in 2006 (#010-2006), which is the one that specifically modified oil recommendations to include 10-60 for certain models, specifically said (bold mine):
1100 SERIES California - Mechanical Tappets
Engine Oil: RACING 4T 10W-60 or as an alternative 20W-50
And I'll note there was no similar "or an an alternative" wording attached to the CARC model recommendations.
  • Administrator
« Reply #38 on: March 27, 2018, 10:23:42 AM »
From what I've studied in the past, SG rating falls within the SN rating.  G is before N. Therefor, any N rated oil also includes G rating and other prior ratings to SN.
where to upload high resolution photos
2001 California EV
Offline kballowe
« Reply #39 on: March 27, 2018, 10:36:39 AM »
I'm not very good at this
I think my point was that "SN" oil is OK.
I apologize for the controversy
After further reading, I have discovered that my owner's manual recommends "a high quality 10W60 motor oil" and goes on to recommend Castrol motor oils.  Castrol only markets one 10W60 motor oil (SN), and I have somehow managed to acquire some of this elusive elixir.
Life is good
Thank-you, everyone.
« Last Edit: March 27, 2018, 10:42:28 AM by kballowe »
Offline TimmyTheHog
« Reply #40 on: March 27, 2018, 10:59:31 AM »
Agreed but for those that don't have this information they are looking for the magic "SG" or now days 4T on the label.
Gives warm and fuzzys!!!
^whatever Luap said.
Unless you are running SUPER OLD CAR and OLD OLD engine, SN can be reversed used for SG.
If you REALLY concerns about it, I do know Motul 7100 4T is rated from SG to SN
Beside SN, SG...or whatever rated, you need to make sure it IS NOT ENERGY CONSERVING, and JASO MA & MA2 rated.
I know we have dry clutch system, so it may not affect us that much, but I simply like to stick to that rule as "shit happens"
« Last Edit: March 27, 2018, 11:11:57 AM by TimmyTheHog »
Currently Bikeless...*cry*
Offline kballowe
« Reply #41 on: March 27, 2018, 11:23:11 AM »
Wow.
THANK-YOU !
8 liters, delivered to my house.  $48 and some change.  "API SG/SH,SJ/SL, CCMC G5 and JASO MA2 certified"
Thanks again.
« Last Edit: March 27, 2018, 11:29:03 AM by kballowe »
« Reply #42 on: March 27, 2018, 12:51:03 PM »
Where did you find
All I'm seeing is SM/SN
I'll buy a few gallons if it is SG..
Edit: After more research it looks as if the only SG rated one is the 5-40.
« Last Edit: March 27, 2018, 01:31:49 PM by Chuck in Indiana »
« Reply #43 on: March 27, 2018, 02:38:51 PM »
There is nothing like an oil thread. :evil:
For those that go back a bit, you may remember a few years ago when a dealer (forgotten who) put a post up saying basically, "what is going on. I suddenly have umpteen bikes ranging from a few tens of thousands of miles to the hundreds of thousands all with failed cams/followers." The oil boffins here said that the oil companies had quietly dropped the zinc loadings. This happened with oil ratings at about the SJ time.
A metallurgist said that the zinc prevented "microwelding" happening as the follower rubbed over the cam surface. Although oil manufacturers had put additives in to improve lubrication, they did not prevent the microwelding happening on flat tappet engines like Guzzis.
For myself, from that I look for the zinc loading rather than the rating. I use 10W/60 because the smallblocks run hot. I have used 10W/50 when the 10W/60 was unavailable. Penrite have the zinc loading on their packaging. That's what I use.
Offline Dilliw
« Reply #44 on: March 27, 2018, 03:37:17 PM »
Love me an oil thread!  My approach is a little different; I just use what Bubbie uses :)
Seriously, there's long thread on a Harley site where a guy named Bubbie who lives in Southeast Arizona switched his modified EVO to Liqui Moly 10W60.  His analysis from Blackstone said he should run it out to 7,500 miles between intervals.
I've been to SE Arizona and I once owned a Harley.  If that oil can handle that combination, with a built motor to boot, I think it will take care of my Griso.
George Westbury
Austin, TX
« Reply #45 on: March 27, 2018, 04:01:00 PM »
SG rated..  :thumb:
Offline blackbuell
« Reply #46 on: March 27, 2018, 05:07:20 PM »
Anybody use Red Line 10W-60?
Jon
« Reply #47 on: March 27, 2018, 06:09:28 PM »
Jon
It's local, and not too expensive. Unfortunately, unlike all their other oils.. it's *not* SG rated. <shrug>
<oil thread in full bloom>
 :smiley:
Online Ncdan
« Reply #48 on: March 27, 2018, 06:36:06 PM »
« Reply #49 on: March 28, 2018, 07:15:17 AM »
Advisory: Check owner's manual to assure appropriate service category and viscosity grade.  API SM engine oil is backwards compatible. As such, it can be safely used in older vehicles. It should be noted, however, that the use of API SM engine oil in some older "muscle cars" with flat tappet camshafts, has been linked to premature wear.  As such, check owner's manual to assure appropriate service category and viscosity grade.
That's all I'm going to say about it.
Offline Dilliw
« Reply #50 on: March 28, 2018, 08:57:03 AM »
Flat tappets???  SG rated oil won't save those in a Guzzi  :evil:
George Westbury
Austin, TX
« Reply #51 on: March 28, 2018, 10:38:09 AM »
 :smiley:
« Reply #52 on: March 28, 2018, 12:25:21 PM »
So what do you thing of using Motoul 20w60 instead?
Online Lee Bruns
« Reply #53 on: March 28, 2018, 12:29:08 PM »
So . . . .buying from the Guzzi dealer is out of the question? God forbid they make a nickel, they might keep their doors open if that happened.
Offline lti_57
  • Directly above the center of the Earth
« Reply #54 on: March 28, 2018, 02:31:55 PM »
I have been using redline 10w-60 for years
but recently found Liqui-moly and have made the switch to that, On my Norge and for my 87  BMW E30
2007 Guzzi Griso
1992 BMW K75
« Reply #55 on: March 28, 2018, 02:34:58 PM »
Many here run Motul 10-60
Meets the following standards: API SL/SH/SG and JASO MA
Offline TimmyTheHog
« Reply #56 on: March 28, 2018, 02:46:52 PM »
+1 with motul...just a bit pricy if not on sale...
Here is a picture of it if you still doubt it
Now, I think thread is long over due to the fire  :afro:
Offline blackbuell
« Reply #57 on: March 28, 2018, 03:40:09 PM »
I used Red Line 10W-60 oil in my 2009 Norge for most of its 55 K mile life (totaled on a deer). Though Red Line oils do not have API ratings, the company claims that their 10W-60 oil is recommended for: API SN/SM/SL/SJ/SH/SG/CF and ACEA A3/B3/B4. Might continue to use it in my recently acquired 2007 Norge.
Jon
Offline jdgretz
  • Proud Owner of a Red Norge
« Reply #58 on: March 29, 2018, 04:10:57 AM »
Jon
Been running it for the last 80,000 miles.  Use their Shockproof 80W in the gear boxes as well.
jdg
1999 Honda Helix - Zippy
2008 Honda Goldwing
  • Administrator
« Reply #59 on: March 29, 2018, 05:11:43 PM »
Wow, ordered 2 gallons Tuesday at noon, shipped for $48. Came home from work today (Thursday) and they're on my front porch.  That's pretty awesome considering where I live.
Oh, after doing more research on silkolene, I did find this little bit of info on revzilla (where it's $16 a quart):
* Developed and tested in World and National Superbike Racing
* High Viscosity Index, exceptional shear strength and outstanding thermal stability give excellent �stay-in-grade" performance
* Outstanding anti-wear, anti-friction and load-carrying properties
* Meets or exceeds API-SF and SG standards
* Motorcycle 4T JASO-MA certified
« Last Edit: March 29, 2018, 05:12:20 PM by Luap McKeever »
2001 California EV
