Author Topic: Steering Damper '86 LeMans info .  (Read 2129 times)
Offline mcdammitt
  • Do like the Hindu, the best you kin do
« on: March 25, 2018, 11:02:45 AM »
On my '86 LeMans, any suggestions on steering damper?  Any one know the original length and stroke?
-Scott
« Last Edit: March 26, 2018, 09:25:21 AM by oldbike54 »
'03 EV w/Champion sidecar
'73 Eldo
'69 Triumph Bonney
'47 Nimbus
'72 Norton Commando
'81 Laverda 1200
Offline yogidozer
Re: Steering Damp
« Reply #2 on: March 25, 2018, 01:50:07 PM »
are you able to tell the difference if you have one on or not? usually not
Offline pressureangle
Re: Steering Damp
« Reply #3 on: March 25, 2018, 03:37:44 PM »
My '85 LMIV damper was finished, I never did get around to installing another one- went 35,000 miles without. It does, however, have an 18" front wheel and steel clamps, making it doubly stable and hard as a pig to steer. I don't care since I don't live in the mountains. Never felt the need to put one on it.
That said, I highly recommend that you have one. Because you never know you need it until you need it.
Re: Steering Damp
« Reply #4 on: March 25, 2018, 06:52:16 PM »
 If you have one and don't know whether or not it works, then it works.
 If you are on the ground after a tank slapper, it didn't work.
Offline Carlo DeSantis
Re: Steering Damp
« Reply #5 on: March 25, 2018, 09:56:38 PM »
This ^^^^^
Best,
Carlo
Chuck in Illinois
Crystal Lake, IL USA
'75 850 T3 Custom
'11 R1200R
Offline flower_king001
Re: Steering Damp
« Reply #6 on: March 26, 2018, 09:21:39 AM »
I have owned a 86' Lemans for over 20 years. My damper feel apart on the Dragon 5 years ago and took it off. Never noticed any difference so I never replaced it.
Brian
1971 BMW R90/5
1998 Moto Guzzi 1100 EV
2005 BMW 1200 RT
2007 BMW 1200 GS
2007 Moto Guzzi Breva 1100
Offline double.d
Re: Steering Damper '86 LeMans info .
« Reply #7 on: March 27, 2018, 12:41:37 AM »
I rode once without a damper and it felt odd................ .......... twitchy. There would be a lot of varying factors for people to say it either needs or does not need one but i'll verify what has already been said, if the bike came with one there will be a good reason.
1986 Le Mans IV Black Since New
2014 K1300 R Black German Starship.
Online wirespokes
« Reply #8 on: March 28, 2018, 02:57:26 AM »
Does yours still have the 16" front wheel? What shape were the tires in - rear needing replaced? Front questionable?
Offline Stevex
« Reply #9 on: March 28, 2018, 02:12:12 PM »
In the early eighties I had a steering damper-less Le Mans 2 go into a tank slapper.
The road was excessively bumpy and the end result wasn't pretty.
Guzzi fit them for a reason, you might only ever need it once, but if it's not fitted...
kirby1923
« Reply #10 on: March 28, 2018, 06:43:11 PM »
I had my CX go into some pretty wild gyrations once. It was with fairly wavy slightly rough pavement with high lean angle at triple digits (well close anyway, too fast)...
It had the stock damper (friction) and I had it lose.(low friction)
Since then I have installed a hydraulic damper with 3 different settings. I went to the same road and couldn't duplicate...happy, no surprises like that please.
Sourced damper from MG cycle, and required no modification on the bike to install.
FWIW
« Last Edit: March 28, 2018, 06:44:32 PM by kirby1923 »
