Author Topic: Ziptie guzzi  (Read 2942 times)
Offline Bobbytinder
Ziptie guzzi
« on: April 02, 2018, 08:18:43 PM »
I recently purchased my first Guzzi, a 2007 Breva 750, and the previous owner was nice enough to use a zip-tie instead of the proper part. Any idea what part and/or part number this is? It looks to be some sort of idle set screw. Thanks in advance!
Online fotoguzzi
Offline antmanbee
Re: Ziptie guzzi
« Reply #2 on: April 02, 2018, 08:36:45 PM »
Looks like it may be the fast idle cam for starting. No real need for it as all it does is open the butterfly a bit when you start the bike. It is actuated by a lever on the handle bar.
Just open the throttle a bit as you start the bike and it will do the same thing.
Re: Ziptie guzzi
« Reply #3 on: April 02, 2018, 08:39:46 PM »
Parts:
motointernational.c om
mgcycle.com
af1racing.com
Offline Bobbytinder
Re: Ziptie guzzi
« Reply #4 on: April 02, 2018, 08:44:47 PM »
here's a link to the parts manual..
http://www.thisoldtractor.com/mg_manuals/spare_parts_catalog_breva_750_2003.pdf
find more small block info here,
http://www.thisoldtractor.com/moto_guzzi_small_blocks_spare_parts_catalogs___exploded_parts_diagrams___parts_fiche.html
Thanks for the info! I was actually looking at the part catalog earlier but couldn't really pinpoint the exact part, any insight would be appreciated.
Offline Bobbytinder
Re: Ziptie guzzi
« Reply #5 on: April 02, 2018, 08:48:08 PM »
Interesting, I fiddled with it a bit while the bike was running and it seemed to change the bikes idle speed. I had no idea that lever was even there! Any idea what the part number is?
Re: Ziptie guzzi
« Reply #6 on: April 02, 2018, 08:50:09 PM »
 I think all you're missing is the cable that actuates the fast idle cam .
Offline Bobbytinder
Re: Ziptie guzzi
« Reply #7 on: April 02, 2018, 08:59:09 PM »
Thanks, everyone! It looks like I found it GU32137010
Re: Ziptie guzzi
« Reply #8 on: April 02, 2018, 09:48:08 PM »
You will also need the spring if the lever on handlebar works.
Re: Ziptie guzzi
« Reply #9 on: April 03, 2018, 02:50:44 PM »
The only time I use the fast idle is when the temps drop and I want to up the idle speed  a bit to get the oil circulating. I never actually warm the bike up but do make sure that the oil has had time to lubricate those sticks thrashing around inside before I ride.
Re: Ziptie guzzi
« Reply #10 on: April 03, 2018, 02:58:46 PM »
No doubt the ziptie was a result of too much vibration...and a roadside repair! :shocked: :huh: :rolleyes: :laugh: :grin: :wink:  "Hell Hath No Fury..." like a ZIPTIE Guzzi!! :thumb: :cool: :1:
