NGC: Tire gurus, school me on inner tubes
Topic: NGC: Tire gurus, school me on inner tubes (Read 2524 times)
JoeB
April 08, 2018, 07:27:08 AM »
Looking to put new tires on a Suzy dr 400s. Need to use inner tubes.
Probably according to modern classifications I'm riding 80% road and the other 20% is dirt and gravel. Am not doing anything like dropping pressure for better traction.
Never gave tubes much thought and used what was locally available.
Question is there any advantage or disadvantage of using a heavy inner tube? Have searched and seen varying opinions.
Would like to know yours.
Thanks, have a good one.
Sheepdog
2007 Moto Guzzi California Vintage
Re: NGC: Tire gurus, school me on inner tubes
Reply #1 on:
April 08, 2018, 08:31:26 AM »
I used a heavy Michelin tube on the front of my Vintage and never had a flat (but fronts are almost never the tire to go flat). It was okay, but the bike seemed to steer better with a standard weight tube. I only used it once. I find that though Metzler and Michelin tubes are premium bits, generic, standard-weight butyl tubes seem to work just as well...especially for a lightweight bike. Try adding a little talcum powder to the inside of the tire/tube when spooning them on. It will reduce heat inside the tire carcass while you’re riding.
Scud
Reply #2 on:
April 08, 2018, 09:28:35 AM »
Many dirt riders use heavy duty tubes if they are going to run low pressures for traction. The heavy tube is less likely to get pinch-flat in that scenario. Since you are riding mostly street and high pressures, I'd suggest standard tubes (with talcum powder per above).
On a related note: do your wheels have rim locks? If not, you couldn't run low pressures anyway. If so, you might want to get some spoke weights to balance the wheels for street use.
1989 Moto Guzzi LeMans
2017 Husqvarna 701 Enduro
2017 Moto Guzzi Stelvio NTX
2020 Yamaha TW200
Antietam Classic Cycle
Happily stuck in the past.
Reply #3 on:
April 08, 2018, 09:50:27 AM »
Metzeler tubes (at least the ones I was getting up until I stopped buying them) are made in China now. I prefer IRC tubes, made in Japan, excellent quality at a reasonable cost.
Heavy tubes will build up heat faster and (of course) add to unsprung weight.
antmanbee
Reply #4 on:
April 08, 2018, 09:52:56 AM »
I always use IRC too. But I think many I get are made in Thailand. But the quality is good.
mcdammitt
Hatchling
Do like the Hindu, the best you kin do
Reply #5 on:
April 08, 2018, 10:38:23 AM »
little round balloons that go inside your tire. Careful don't pinch..............
'03 EV w/Champion sidecar
'73 Eldo
'69 Triumph Bonney
'47 Nimbus
'72 Norton Commando
'81 Laverda 1200
Guzzistajohn
Reply #6 on:
April 08, 2018, 10:47:24 AM »
I use heavy duty tubes on my KTM woods bike. We have some really rocky rough terrain in the ozarks. Flat tires in the hills miles away from the truck really suck!
rodekyll
Not my real name
Reply #7 on:
April 08, 2018, 04:08:32 PM »
I use standard tubes unless I need HD for running heavy. The heat, weight, and more difficult installation makes HD tubes a less attractive option. Ymmv.
fotoguzzi
vee git tooh soon oldt und too late wise -my Dad
Reply #8 on:
April 08, 2018, 04:13:46 PM »
On my DR I use (Bridgestone?) I know they said
made in Japan
and that gives me a warm fuzzy feeling.
wirespokes
Reply #9 on:
April 08, 2018, 06:11:00 PM »
On the R80G/S I've run 20lbs on rough roads, but don't go very fast at that pressure - no faster than 40 or 50 at most. Never a problem.
I haven't bought any new tubes in forever - have to remember that about IRC.
kingoffleece
SplitWeight(tm) seat covers
Rated 5 STARS Motorcycle Consumer News
Reply #10 on:
April 08, 2018, 07:07:21 PM »
I was under the impression that synthetic tubes hold air "better" and don't bleed pressure as much. Downside is that when the fail it's a big bang. Natural rubber will fail in a less spectacular event, but bleed off pressure at a greater rate than synthetic. I use the natural rubber tubes in case this is correct. I do trust my source, though.
kballowe
- Kevin the Great -
Reply #11 on:
April 09, 2018, 12:31:22 PM »
We change a lot of tires.
In the past few years, many of the high-end brands moved manufacturing to China, and for the worse - but they STILL want that high price !
The Genuine Harley tubes used to be U.S. made and very good quality, but they have also gone to crap.
We have been using a lot of Kenda or IRC or whatever Drag Specialties is shipping and they have given good service.
Standard tubes.
Typically - if a wheel shows up with a rim lock, then it gets a heavy-duty tube. Otherwise, it gets a standard tube.
