Author Topic: Are red valve covers available for sale anywhere  (Read 1827 times)
Offline Numbercruncher
« on: April 10, 2018, 04:13:45 PM »
I like the look of the red valve covers on the V7III carbon dark but that bike is quite a bit more money than a regular VIII and while the carbon components look cool, I may be just as happy with a V7III stone and adding the red covers.  I don't see them shown as an accessory but maybe someone here has sourced them before.
Thanks.
NC
Offline Toecutter
Re: Are red valve covers available for sale anywhere
« Reply #1 on: April 10, 2018, 04:15:43 PM »
At "Guzzi prices" for parts... you'd be better off to bring them to a local powder coater. See if you can piggy back on another, larger, order in the colour you want. If you're not in a rush, and they have an order for a colour that you dig... you can get a better deal sometimes.
Online rodekyll
« Reply #2 on: April 10, 2018, 05:26:40 PM »
I'd go with toe's assessment, and add that you can go to websites like powderbuythepound and Rosie's and buy the color you want.  They all shoot the same (although they might cure differently), so presenting a half-pound of your favorite shade of red to the powdercoating shop shouldn't bother them.  You can get RAL colors, which are a spectrum of industry standard shades, or the specialty powders unique to the various websites.  If a clear coat is recommended, they come in many lusters from flat to 100% gloss.  You might want to choose your clear coat based on the shine you want.  For example, to preserve the look of blasted aluminum, you'd want a zero gloss clear.  To make a candy colors pop you'd want high gloss.  The powder seller's websites are usually really good at explaining the differences, and I've never been disappointed by the phone conversations I've had with any of the suppliers I've dealt with.
A caveat on powder coating used parts:  They must be cleaned to the pore level to remove any oil or other contamination.  At the 400ºf cure temp anything in the metal itself will outgas and ruin the powder.  Get the job done sooner than later to minimize the metal contamination and let the shop do the prep.  You'll still beat the cost of oem red covers.
« Reply #3 on: April 10, 2018, 07:06:46 PM »
Excellent advice; as usual.
NC
« Reply #4 on: April 10, 2018, 07:09:09 PM »
A caveat on powder coating used parts:  They must be cleaned to the pore level to remove any oil or other contamination.  At the 400�f cure temp anything in the metal itself will outgas and ruin the powder.  Get the job done sooner than later to minimize the metal contamination and let the shop do the prep.  You'll still beat the cost of oem red covers.
Does baking the naked part first to be sure to outgas anything left in the metal, then cool, coat, and rebake help?
Offline dl.allen
« Reply #5 on: April 10, 2018, 07:18:31 PM »
I would simmer them in boiling water with dawn detergent
Online rodekyll
« Reply #6 on: April 10, 2018, 08:01:52 PM »
Yes it does.  I often do a run at temp +25º/time without coating to be sure I got all the crud.
Online LowRyter
« Reply #7 on: April 10, 2018, 08:06:47 PM »
Try this
https://www.amazon.com/Dupli-Color-BCC0419-Chrysler-Perfect-Automotive/dp/B00407YPPK
corvette roman red.  dodge flame red.
guzzi spine frame red   :thumb:
