Author Topic: Tire repair or replace?  (Read 4103 times)
Offline Irn
  • 2004 Breva750 2007 BMW F800ST 2006 Vespa GTS2500
« on: April 12, 2018, 03:33:31 PM »
Picked up a sheet metal screw yesterday. I was lucky my F800ST has a TPMS read out, watched the rear tire go from 37-20  while I slowly made it to the nearest town 5 miles away.  Once there, looking stranded at a gas station a nice guy in a Chevy Club Cab asked me what was wrong, and offered me a tire auger and a plug.  Presto, fixo, made it the 50 miles back to my house.  No tow, and no accident, all in all, a very good day.  The tire is a Michelin Pilot Road 4.  The puncture was about an inch off the center of the tread.  Of course, the tire only has 1k on it?  Replace, or try to find someone who will put a rubber plug with cement and a patch on the inside.  New tire to match the front about $200.  What say you wise Guzzi folks?
Re: Tire repair or replace?
« Reply #1 on: April 12, 2018, 03:35:07 PM »
Replace
Offline pyoungbl
« Reply #2 on: April 12, 2018, 03:35:34 PM »
Ride it....and monitor the pressure.
Peter Y.
'13 V7 Special (red/white)
« Reply #3 on: April 12, 2018, 03:36:40 PM »
If you have the dough, shop around and find a new one on sale and save it back until you've ridden the repaired tire down to replacement tread  OR it will no longer hold air reliably OR you're gearing up for a long, long trip, then swap...YMMV
Offline yogidozer
« Reply #4 on: April 12, 2018, 03:43:47 PM »
I would continue riding with it. Like Peter says, monitor the air pressure. Doubt you'll have a problem.
Offline malik
« Reply #5 on: April 12, 2018, 03:50:47 PM »
The normal fibre & cement plugs seem to eject themselves quickly with high speed riding. The mushroom plugs work better, but even these try to escape the hole and leak, so you would have to avoid spirited riding. Where's the fun in that. Replace the tyre.
Offline ejs
« Reply #6 on: April 12, 2018, 04:07:37 PM »
 :weiner:
Have used  mushroom plugs 2 times in rear wheel.
No problems.😁
California EV 1999
« Reply #7 on: April 12, 2018, 04:20:12 PM »
:weiner:
No problems.😁
This ^^. How does a mushroom plug "escape"? The ones I've used had a head ~ 1.5" in diameter, goes in the hole from the inside and is glued in place, with air pressure against it.
« Reply #8 on: April 12, 2018, 04:25:57 PM »
 ride it.
Don't mess with it unless it leaks.  If so, replace the tire.  I've never been able to fix a bad repair.
I recommend that riders carry Stop and Go plug kit.
« Last Edit: April 12, 2018, 04:28:48 PM by LowRyter »
« Reply #9 on: April 12, 2018, 04:29:45 PM »
:weiner:
No problems.😁
Offline yogidozer
« Reply #10 on: April 12, 2018, 04:33:31 PM »
ride it.
and one of these too.
http://www.aerostich.com/a-to-b-utilities/tools/tire-repair/pumps-air-compressors/engineair-power-pump.html
« Reply #11 on: April 12, 2018, 04:51:31 PM »
Run it around town and short rides.  Any trip involving prolonged speeds and heat built up such as Summer touring replace it before your trip.
« Reply #12 on: April 12, 2018, 04:56:30 PM »
If it's an H rated tire good for 130 mph, keep it to the lower rating and don't ride over 124 mph.   :thumb:
Offline malik
« Reply #13 on: April 12, 2018, 05:00:12 PM »
Beats me. But I've seen it happen. My neice bought a CB500 with 8,000km on it. A few months later she got a slow leak. The stem of a mushroom plug was protruding some 3-5mm out into the air. Bit the bullet & replaced the tyre (a few days before she left on a 6,000km trip).
On the other hand, I've a mate with a 1200GS, ended up with dozens of the Stop n Go mushrooms  in a tyre on a ride through Eastern Europe, Turkey & the Sahara. Lasted till the tread wore out. I'd guess new tyres would be hard to find in the Sahara, so not a lot of choice.
Offline Thunderbutt
« Reply #14 on: April 12, 2018, 05:01:23 PM »
Im- have you checked with the location you purchased the tire for a road hazard warranty?  I thought the Michelin tires had some type of road hazard warranty when you purchased them?
Current rides:, 2002 LeMans,  2020 V-85TT Travel, 2019 DR650
Offline clubman
« Reply #15 on: April 12, 2018, 05:02:16 PM »
Everybody is going to tell you the safest thing is to replace it and that is correct. However, if you are going to try to get full use out of the tire the correct way is 1:demount the tire and closely inspect for cord damage or hidden tears. 2: Put on a hot patch from the inside. I've seen it done dozens of times on commercial tires with no failures. Plugs installed from the outside are intended for temporary get home repairs. Going beyond that is pressing your luck. My dos centavos.
« Reply #16 on: April 12, 2018, 05:07:53 PM »
Plug/patch combo is the best way.  Carquest has them.  Don't be stingy on the glue.  That seems to be the biggest problem on plug repairs.
https://shop.advanceautoparts.com/p/xtra-seal-med-unvsl-patch-plug-13-383/28200216-P?searchTerm=tire+plug+patch+kits
« Last Edit: April 12, 2018, 05:12:11 PM by Tom »
Offline Texas Turnip
« Reply #17 on: April 12, 2018, 05:32:54 PM »
Clubman gave you the perfect answer.
This topic pops up like a pimple at your wedding. Usually someone will say, "if you value your life."
Tex
« Reply #18 on: April 12, 2018, 05:51:54 PM »
Plug it correctly from the inside.
« Reply #19 on: April 12, 2018, 06:56:09 PM »
"Gooey string" plug. Used them a number of times in motorcycle and car tires. Keep going until you wear it out. The exotic plugs are less reliable IMHO.
« Reply #20 on: April 12, 2018, 08:52:01 PM »
Don't mess with it.   If it leaks throw it out.  Otherwise ride it.
Offline normzone
« Reply #21 on: April 12, 2018, 11:23:48 PM »
Put about eight or twelve tubes of kitchen caulking inside the tire, thereby developing a solid rubber tire like our first bicycles had - at least mine did.
 :evil:
Offline kirkkw
« Reply #22 on: April 13, 2018, 12:30:06 AM »
I have 2 patches in my rear tire.  Take it off and take to Discount Tire and they will put a patch on the inside of a tubeless tire for FREE.  Or at least they did for me 2 tires.    :popcorn:
« Reply #23 on: April 13, 2018, 09:47:36 AM »
for FREE
Welcome to WG, and nice first post.  :smiley: You have the Guzzi persona down pat already..
Offline Fontain25
« Reply #24 on: April 13, 2018, 10:41:42 AM »
According to car tire manufacturers - ANY type of tire repair then limits the tires max speed to 55mph. Sounded stupid to me , but that was the official word. Probably just a disclaimer.
« Last Edit: April 13, 2018, 11:10:17 AM by Francois25 »
« Reply #25 on: April 13, 2018, 11:11:46 AM »
Just lawyers talkin..
Offline rider33
« Reply #26 on: April 13, 2018, 11:51:24 AM »
I keep a plug kit with all of my bikes (well, the tubeless one's anyway) in case of a flat.  Plugging a tire is typically pretty straight forward and assuming you have air to blow it back up you are good to go.  In a car or on a low pressure tire like a tractor I leave it at that as long as it's holding air.  Motorcycles tho are different.  There you have high speeds, small contact patches, and much greater stresses (why bike tires rarely if ever go beyond 10,000 miles while that would be absurdly low for say a car).  If a bike tire fails it can be catastrophic,  not just inconvenient.  Thus I may hobble along on a patched bike tire but as soon as I can,  it gets replaced. If you've ever lost a tire at speed, you'd under stand why.  Stuff happens but that's no reason to poke the bear.
"some journeys continue long after movement in time and space has ceased"  -Steinbeck
