Author Topic: V7 III tachometer or no tachometer?  (Read 9304 times)
Online bad Chad
Re: V7 III tachometer or no tachometer?
« Reply #30 on: April 18, 2018, 06:08:56 PM »
Thread drift.  I used to bounce of the rev limiter on my Bassa quite often.  Yet I seldom do riding my Breva 1100.  I was thinking at first it was because the Breva is somewhat quicker than the Bassa, but then I recalled I was often riding with Sergio DeSouza while on the Bassa, and he moved to Brazil just before I got the Breva!  Anyone who rode with Sergio, may recall what I'm talking about!
1988 YX600 Radian
Offline organfixsing
« Reply #31 on: April 19, 2018, 12:41:02 AM »
The Rev Limit is set in the ECU firmware and in the case of the V7II, the Rev Cutoff = 7200rpm and the Return Fuelling is 7150rpm.
This information is available using GuzziDiag and TunerPro software to read the ECU firmware settings.
Cheers
Brian :grin:
If you remove the wings of a fly, does that make it a walk?
« Reply #32 on: April 19, 2018, 01:18:00 AM »
I wonder why they dropped the limit? While it might be pointless from a ‘Power’ perspective to rev them higher with the intrinsically better breathing of a hemi head design over the herron head on the previous offerings a lower rev limit seems a trifle odd. Perhaps they are using a particularly soft cam for bottom end? Perhaps they’ve just cheaper out on connecting rods?
Offline Numbercruncher
« Reply #33 on: April 19, 2018, 11:13:19 AM »
Once I am past the horsepower peak I always upshift.  At that time you are making less power and torque and I see no reason to push matters.
V-Strom is cleaned up and listed for sale.  Hoping for a quick turnaround.
NC
