Author Topic: LeMans III Pipes  (Read 3051 times)
Offline MarkPell
LeMans III Pipes
« on: April 24, 2018, 06:57:15 AM »
Hey All,
My LeMans came with 3 sets of pipes, the set that was on it were hand made-looked and sounded great (loud) but bike ran a bit rough at lower rpm's.
Put on Lafranconis last weekend which cleaned up beautifully, not as loud as the hand made set but still sounds pretty damn good and runs much smoother.
Think I will stick with these for now. Third set were painted silver-not sure what they are. (maybe stockers?)
Are the Lafranconi's stock or aftermarket.
Thanks,
Mark
Mark
2000 Kawasaki W650
1983 Lemans III
2019 Road Glide
2006 FJR1300
2007 Rokon Scout
1971 Bultaco Alpina
1971 Rupp Roadster
2006 Aprilia Mojito 150
2010 Vespa 150
Offline acguzzi
Re: LeMans III Pipes
« Reply #1 on: April 24, 2018, 08:43:53 AM »
the lanfranconis are aftermarket but a fairly commonly used "performance" replacement
Offline SPScottNT
« Reply #2 on: April 24, 2018, 08:59:47 AM »
Lafranconi made the stock pipes as well as the aftermarket "Competiziones".  I think the stock pipes will be marked as  "Lafroncnoni",  "Moto Guzzi" and a model number - something like "S-18".  Competiziones have a larger rear exhaust hole and are fitted with red propeller/turbine sort of piece in that rear exhaust hole.
Scott
Athens, GA
Offline Tusayan
« Reply #3 on: April 24, 2018, 09:54:47 AM »
LaFranconi is an exhaust system manufacturer in Mandello Del Lario, a couple of blocks from the Guzzi factory.  Naturally they've made a lot of stock Guzzi exhaust systems (since 1928) and they also make accessory systems for Guzzis, as well as OEM exhausts for other manufacturers like BMW and MV Agusta.
http://www.lafranconisilenziatori.com
Offline Matteo
  • Alaska Guzzi's on Facebook
« Reply #4 on: April 24, 2018, 11:30:39 AM »
This is stamped on my stock pipes: MOTO GUZZI S28
« Last Edit: April 24, 2018, 11:31:30 AM by Matteo »
Offline sdcr
« Reply #5 on: April 24, 2018, 12:33:37 PM »
here are a set of
LaFranconi mufflers on my Le Mans III.
2000 BMW R1100 RS
1983 BMW R100
2009 Jaguar XK
Offline siabeid
« Reply #6 on: April 24, 2018, 03:03:16 PM »
Mine are stock. They are stamped " MotoGuzzi S28."
« Reply #7 on: April 24, 2018, 03:09:19 PM »
Lafranconis here. Love the sound!
Offline MarkPell
« Reply #8 on: April 25, 2018, 06:19:26 AM »
Looks like they are the stockers after all. Marked S-28. Surprised how throaty they are for stockers though?
Either way, I'm going to run them for now....
Mark
2000 Kawasaki W650
1983 Lemans III
2019 Road Glide
2006 FJR1300
2007 Rokon Scout
1971 Bultaco Alpina
1971 Rupp Roadster
2010 Vespa 150
Offline SPScottNT
« Reply #9 on: April 25, 2018, 06:55:02 AM »
Baffles may have been drilled or punched by a previous owner....not an unusual modification to find.  If you look into the muffler from the backside you can probably see the baffle about, by my best recollection, 6 to 8 inches in.
Scott
Athens, GA
Offline sdcr
« Reply #10 on: April 25, 2018, 07:10:01 AM »
My 83 Le Mans came from Cycle Specialties of Athens Ga.. I believe the bike was set up originally by John Hoffman, judging by some of the notations in my service log! which goes back to 1983. I understand that John Hoffman had sold the franchise to another business about 15 years ago. Are they still at the same physical location, carrying the  Moto Guzzi, Ducati line?
Scott
Athens, GA
2000 BMW R1100 RS
1983 BMW R100
2009 Jaguar XK
Offline SPScottNT
« Reply #11 on: April 25, 2018, 09:37:56 AM »
Sadly, Cycle Specialties is no more.  PM sent.
Offline Matteo
« Reply #12 on: April 25, 2018, 10:41:29 AM »
Not that there’s anything wrong with that.😎
Offline MarkPell
« Reply #13 on: April 26, 2018, 06:14:29 AM »
Not that there�s anything wrong with that.😎
Not at all!! Very impressed with the sound, don't feel like the performance dropped at all from the hand made open pipes, runs better and the stockers are in mint shape.  All good!! :thumb:
Bike also has the big bore kit, hotter cams bigger coils. Goes pretty dam good!!
Mark
2000 Kawasaki W650
1983 Lemans III
2019 Road Glide
2006 FJR1300
2007 Rokon Scout
1971 Bultaco Alpina
1971 Rupp Roadster
2010 Vespa 150
