Author Topic: Hyundai AWD system question  (Read 1306 times)
Offline analog kid
« on: April 27, 2018, 11:26:26 AM »
Hi everyone,
I'm working an issue with bro-in-laws SUV. I'm unfamiliar with the particulars of a modern all-wheel-drive system but I've made an observation and my question is: have I found a malfunction or does the system work like that?
Details:
2010 Hyundai Santa Fe GL, V6 3.6L (I think, maybe 3.8L?) . All Wheel Drive, selectable by a dash button - I don't believe it is on-demand.
Issue:
With AWD selected OFF, rhythmic hum from rear end at mid-speeds, 80 - 90 kmh. Not quite the deep growl of a failing wheel bearing, but lighter. more like a whirr or what you feel if you run aggressive tread snow tires (or off road tires, i guess..)
His tires have not been changed (all-seasons are installed, with non-aggressive tread);the issue began suddenly.
Tire visual inspection finds nothing obvious - no damage/thrown belt etc.
Question: when jacked, I spin the LH rear. It spins alone.
                         Spin the RH rear and the LH rear wheel turns with it - like an old style differential in yer dads Oldsmobile.
                         Should it?
                         Is there an electric clutch in the diff that's not disengaging or is this normal system operation? I was thinking both rears                    should freewheel with AWD OFF.
I've not yet surfed the web to find info, but will later.
Sun is shining ! Time to do end-of-season maintenance and snowblower storage!
90 Mille GT
03 Aprilia Caponord
84 LeMans lll (project)
07 Breva 1100 (sold)
Offline Madtownguzzi
Randy S.
98 V11 EV
05 HD Electra Glide Classic
Madison, WI
