Having ridden the V9, I was surprised with it. Real world had enough power to accelerate onto a highway without feeling I was going to be run over. At 60mph, there was still enough left to easily speed up to traffic that was going way over the speed limit. I figure that as long as it has that, it should do fine. More is better I guess but I didn't feel slighted with the V9 Roamer.On another note, and this is a question to the collective. Do I remember that for some reason all HP and Torque curves cross each other at 5250rpm's for some reason? Or, is that a thing of the past with modern designs?Don't know if that really matters other than my curiosity.John Henry
It�ll definitely be interesting to see how the engine management works. 52mm TB and only single valves are going to be an interesting combination. One assumes idle is going to be spark controlled like the Cali 14�s as I�d think getting throttle plate activation to be sensitive enough to get the idle under 2-2.5k would be damn near impossible!The problem isn�t the amount of power it produces per-se, it�s what the public perception will be. Quite simply most potential buyers will look at the spec sheet and be so underwhelmed they simply won�t try it. As it is I�m disappointed it�s still a 2V OHV engine as I think a smaller 4V Hi-Cam would be enormous fun. Hopefully that will be down the line somewhere as the heads and rocker gear on the V9 seem to suggest it.Pete
I don�t doubt that it could bring back owners who are so shackled to the past and averse to technological developments that they are worried about things like multi valve engines, fuel injection and plastic fuel tanks but most of the world has moved on and it�s �Most of the world� of motorcycling who will make or break the success of the model.I really hope it�s a great machine and I also really hope you buy one and are happy.Pete
Actually Martin Grisos are holding up reasonably well. It�s 1200 Sport 8V�s that are the absolute bargain. Owners can�t give them away! If I wasn�t knee deep in the 1400 Stelvio nonsense I�d probably buy one simply because they are such a big, comfortable slug of a thing.The only 8V�s that are actually commanding money are big tank Stelvios, (Boy I wish I could pick up a couple of those cheap!) and 8V Norge�s which over here are as rare as rocking horse shit because they only bought a few in and AFAIK they are all flatties and need rollerising.Not really any different to any other bike in the current marketplace really. Truth of the matter is nobody much buys second hand ATM.Pete
but they sold lemons, knowingly.
Thanks, as always, Dogwalker for sharing what you've found!
Gotta agree. They were still selling the 4Vs when they (must have known) they were a time bomb. If they didn't know.. there was some piss poor engineering involved. Maybe it was bean counter driven? No matter which, it was a serious hit on their reputation.
80 HP with 2 valves and pushrods? I think not.
My old LM3 had 76 hp, with basically the same engine size, 2 valves, pushrods etc... Looking at it like they should be ashamed, no progress in 30+ years... though the new one will be hindered more by environmental restrictions...
You are welcome.About the choice of mantainig the classic pushrods configuration, Cappellini made some considerations that makes sense. That's a very efficient setup. There are very few energy dispersions (only one camshaft to move, no water pump, no high-flow oil pump for an air/oil cooling...) so, to reach those performances with that setup means to consume less.
On that I agree, the fact they continued to sell flat tappet bikes knowing they were going to fail and then tried to wriggle out of their responsibility was unconscionable but as I’ve stated before I believe that the engine was originally designed with roller tappets and the flat tappet option was the result of bean counting, not engineering.Pete
If you doubt the ability of an aircooled, mid-capacity, 2V, pushrod engine to produce 80 hp, check out this 50 year old Triumph production racer 'Slippery Sam' https://en.wikipedia.org/wiki/Slippery_SamEngine Three cylinder, four strokeDisplacement 750 ccBore & Stroke 67mm x 70mmValvetrain twin camshaft ohv (pushrod), 2 valveCompression ratio Maximum power 84 bhp (63 kW) at 8,250 rpmMaximum torque Oil system Dry sumpCooling system air cooledTransmission Five speedDrivetrain ChainBrakes Front: twin discRear: single discDry weight
Your LM3 had 60hp (on a good day) at the wheel. This will have 65hp and meet the strict new Euro regulations while getting a lot better mpg's and being more reliable.
3 cyl race engine
