Author Topic: Turn Signals Don't Work - Baffled, only 10 volts at each socket  (Read 1815 times)
Offline Ted
1976 T3 turn signals worked in fall of 2017 but don't work now. I have done the following using a multimeter: (1) set it to ohms with ignition off and got continuity to earth/ground on the two connectors, one showed zero and the other didn’t (on both left & right sides) – neither showed infinite resistance. (2) Switched meter to volts, turned ignition on and turned signal switch to left signals and then to right signals – checked voltage between positive lead in the socket and earth/ground (in the socket) and got 10 volts both sides (I was baffled, should have 12 volts). No breaks indicated in either positive or ground wires. Also no shorts found. (3) Checked all 4 bulbs – all were good. (4) Changed out flasher relay – still no turn signals. Somewhere there is something chewing up 2 volts. Any suggestions would be appreciated.
Thanks,
Ted
Re: Turn Signals Don't Work - Baffled, only 10 volts at each socket
« Reply #1 on: April 29, 2018, 02:06:15 PM »
Do they come on at all?
« Reply #2 on: April 29, 2018, 02:16:58 PM »
Bad flasher or flasher wiring.
Offline StuCorpe
« Reply #3 on: April 29, 2018, 02:27:01 PM »
Bad flasher indicator lamp?
Offline BikeMike
« Reply #4 on: April 29, 2018, 02:46:39 PM »
Ted,
Test the voltage from positive lead at socket as in step 2 to negative at battery terminal instead.  If this reading is now at full battery voltage I suspect a poor ground return path is the problem.
Mike
1975 850T Interceptor
1976 V1000 Convert Police
1949 Matchless G3L
Offline injundave
« Reply #5 on: April 29, 2018, 04:44:34 PM »
I had a similar problem with my '75 T3 which, to cut a long and frustrating story short, was cured by running an earth from the turn signal bracket to the frame and ensuring all the signal mountings were tight.
1975 850 T3
2019 V85TT
Offline Ted
« Reply #6 on: April 30, 2018, 08:19:42 AM »
Thanks for all of the suggestions - I will try them all. In answer to one question ("Do they come on at all?") - none of the turn signals come on at all. Thanks again.
Ted
Offline TOMB
« Reply #7 on: April 30, 2018, 08:49:21 AM »
I just fixed the same problem on my convert turns out it was the wire on the fuse block the connection was tight but it was so corroded it was high resistance open no voltage at all move the wire wiggle it around and guess what turn signals work and my bike the way it was wired it's on the left side of the fuse block the blue wire towards the bottom good luck
TOMB
TOMB
CENTRAL CONNECTICUT
1972 AMBASSADOR 169000 MILES
1978 G5 170000 MILES
1973 V7 SPORT 25000 MILES
1973 ELDORADO 300000+ MILES
1980 CX100 50 MILES
MGNOC # 2723
« Reply #8 on: April 30, 2018, 01:47:02 PM »
For troubleshooting you can short out the flasher, this should then make the lamps come on full not having to wait for the flasher contacts to close.
Select Left or right and trace the Voltage relative to chassis
Should have 12 Volts at the flasher and each lamp
Zero on the ground wires
