Author Topic: [CARC] Coil End of Spark Plug Wires Snap-on or Screw-on Terminals?  (Read 2167 times)
Bonaventure
I was wondering if the end of the spark plug leads have conventional snap-on terminal at the coil end or is it a screw-in type.
Crimp on terminal.
Offline TimmyTheHog
Crimp on terminal.
oh? then how easy would it be if I were say to change the coil leads?
Or is this one of them things, don't touch if you don't want to F. it up?
Currently Bikeless...*cry*
Online John A
It's a simple job if you get the correct size terminal ends and rubber boots, and wire size. assuming your going to make your own leads. The correct crimper helps too.
