Author Topic: any lighter rotors out there for Lemans IV?  (Read 2514 times)
Offline lazlokovacs
« on: May 02, 2018, 12:26:25 PM »
I'm tired of my instant-rusting boat anchor rotors that squeak like mad everytime I get to traffic lights
Anyone know of any upgrades?
found these at hmb
http://hmb-guzzi.de/Brake-Disc-front-rear-270-mm-outer-ring-LM-1000-Cali-3-SP-3-etc-stainless
but apparently they weigh about the same as stock
any ideas?
Or are there any 16" japanese front wheels out there that could be swapped in fairly easily?
Would love to lose some unsprung weight esp up front
Offline Turin
Re: any lighter rotors out there for Lemans IV?
« Reply #1 on: May 02, 2018, 01:59:35 PM »
If you're trying to lose in spring weight, there is a dymag wheel on eBay.
That 16 inch hoop weighs a ton.
I prefer iron rotors over stainless.
1985 Sidlow Guzzi
Offline Groover
    • Scooteropolis
1981 Moto Guzzi V1000G5
1987 Moto Guzzi LM1000SE, a
1987 Moto Guzzi LM1000SE, b
1980 Piaggio Vespa P200E
1980 Piaggio Vespa P125X
1980 Vespa Grande Moped
1980 Vespa SI Moped
http://scooteropolis.com/
Offline twhitaker
« Reply #3 on: May 02, 2018, 04:06:06 PM »
Vll LeMans
« Last Edit: May 02, 2018, 04:07:00 PM by twhitaker »
'97 Centauro yellow 25,000 mi
MGNOC-11168
Dayton, OH
Offline flangeman_70
« Reply #4 on: May 02, 2018, 07:21:47 PM »
I have those you referenced on my SPIII.
They weigh a ton, each, rust, the surfaces are heavily pitted and just found this week 2 huge radial cracks in one disc.
They squeal horribly with standard pads. The surface just glazed up. I am using a. Sintered pad which greatly improved stopping, stopped squealing and not obvious differences in wear rates.
The discs are 5 years old and have done 50000km with winter riding also.
Adam
Adam
SP III 1990
V10 Centauro 1996
Offline Turin
« Reply #5 on: May 02, 2018, 09:00:57 PM »
V11 lemans has 6 bolts for caliper mounting.
this dymag has 5.
1985 Sidlow Guzzi
Offline lazlokovacs
« Reply #6 on: May 03, 2018, 02:28:11 AM »
Adam
you mean the OM ones or the replacement HMB discs?
« Reply #7 on: May 03, 2018, 09:45:39 AM »
Replacement items.
300mm up front and 270mm rear
Adam
SP III 1990
V10 Centauro 1996
Offline lazlokovacs
« Reply #8 on: May 03, 2018, 04:01:18 PM »
thanks for the info, I might give those a miss then! :shocked:
Offline Turin
« Reply #9 on: May 03, 2018, 08:14:08 PM »
If you go with a bigger rotor, you'll need adapters as well. see old add:
http://www.dropbears.com/s/sda/p62.htm
1985 Sidlow Guzzi
