Author Topic: MI general alarm now off!  (Read 6036 times)
Offline Rich A
« on: May 17, 2018, 07:50:39 AM »
2017 V7III Special with ~300 mi. General engine alarm is on, solid orange, not blinking. No error message on screen. Oil level checked and OK. Bike seems be be running fine, no hiccups.
I'm thinking one possibility is a bad lambda sensor. I think I can check the lambda sensors with Guzzidiag--is this correct? Any other suggestions for things to check would be appreciated.
The dealer is 4.5 hours away.
Rich A
Update: I checked the lambda sensors and some other readings with Guzzidiag--everything seems to be ok. Cleared the alarm and the light has stayed off. Time to ride!
« Last Edit: May 18, 2018, 12:29:35 PM by Rich A »
Re: General engine alarm!
« Reply #1 on: May 17, 2018, 07:59:18 AM »
Rich A
May have nothing to do with your bike's system, but on my Stelvio, that very thing would happen when the Speedometer Sensor on the back wheel would get wet.    Dried it and sealed it and doesn't happen any more.
Offline JohninVT
« Reply #2 on: May 17, 2018, 08:04:40 AM »
How the hell did you figure that out?  It must have taken a looooong time through the process of elimination to discover.
« Reply #3 on: May 17, 2018, 08:10:55 AM »
Wild Guzzi, of course!   Wayne Orwig, if I remember correctly ... along with the solution of drying it with a hair-dryer, and dipping it in silicone to seal up where the wire goes into the sensor.   I bought a new sensor, but 50,000 miles later it's still on the shelf ... !
Matter of fact, I found the 8-year-old thread .... http://wildguzzi.com/forum/index.php?topic=41520.0
Lots of people helped.
« Last Edit: May 17, 2018, 08:26:51 AM by Lannis »
Offline Rich A
« Reply #4 on: May 17, 2018, 08:33:16 AM »
I'm in New Mexico. We haven't had any rain for at least a month, so that's likely not the problem.
Rich
« Reply #5 on: May 17, 2018, 08:55:15 AM »
If you have that ABS/traction control stuff on that bike you may look there. All I could think of.
Offline Guzzi Gal
    • Sonoran Sunriders, YouTube
« Reply #6 on: May 17, 2018, 04:58:37 PM »
I had the same issue so I read the manual cover to cover (again) and traction control was the only light that fit the bill.  Ran it through the calibrate protocols and all was fixed.
"Velvet" '16 Honda CTX 700,
"Miri" and Mori"
Offline Rich A
« Reply #7 on: May 17, 2018, 05:25:08 PM »
It's the MI general alarm light that is lit, the one that looks like an automobile engine. There's separate light for the MGCT (traction control)--it's not that one that's lit. I don't see anything in the manual that connects the MGCT to the MI general alarm light.
« Last Edit: May 17, 2018, 05:39:51 PM by Rich A »
Offline kballowe
  • - Kevin the Great -
Re: Correction it's the MI general alarm!
« Reply #8 on: May 17, 2018, 05:52:05 PM »
Rich A
Mine did that at 97 miles.  First time we got a really hot day.  Same as yours - oil full - no funky noises, etc.
Started it up the next day and the light was off.
There are a few threads out there that blame it on an oxygen sensor.  It doesn't throw an error code, either
Offline Rich A
« Reply #9 on: May 17, 2018, 06:02:28 PM »
I'm trying to find out if Guzzidiag will show a bad lambda/oxygen sensor. It looks as though there are several options for lambda sensor readings in the menus.
Rich
« Reply #10 on: May 17, 2018, 07:40:34 PM »
Calibrate protocols?   Please educate me, as I'm a new V7-III owner.
Offline Rich A
« Reply #11 on: May 17, 2018, 07:54:29 PM »
P. 52 of the manual
MGCT SYSTEM CALIBRATION PROCEDURE In order to maintain the effectiveness of the MGCT system following the replacement of one or both tyres or in the case of serious wear, causing a non-compliant behaviour of the MGCT, a calibration procedure of the system must be performed as follows on a straight flat stretch of road.
Check that the tyres are inflated to the correct pressure before calibrating the MGCT system.
• Allow the engine to idle for at least 5 seconds.
• Check that the MGCT is activated at level 1 or 2. Otherwise, activate it.
• Pull the clutch lever while pressing the starter button (3) for at least 5 seconds. The activation of the process will be confirmed by the MGCT warning light (2) turning on with fast flashing.
• Accelerate to a constant speed of 30 km/h (18.64 mph) in second gear, and maintain this speed for at least 8 seconds.
• The end of the procedure will be indicated by the MGCT warning light (2) turning off. The MGCT system is active.
• Once the procedure is completed, it is necessary to switch the ignition key to (OFF) and wait for at least 60 seconds before being able to switch again to (ON).
• In case of failure to complete the procedure within 2 minutes, the MGCT warning light (2) will stay on steady and the MGCT system will remain off until switching to (OFF).
• To reactivate the MGCT system, it must be switched again to (ON). It is however necessary to repeat the process until it succeeds.
Offline Mike123456
    • Guzzi
Re: MI general alarm now off!
« Reply #12 on: May 23, 2018, 08:56:20 AM »
I had the same issue on a newish v7iii. After using some Google-fu, I found that the most common issue is caused by a faulty sensor, and the second most common cause was loose connections. I tried the latter and lo' and behold, after "fiddling" and checking connections under the tank area, the problem was solved. I don't know which wire/connection it was, but it worked!
Hope that helps someone
Mike
Sent from my Pixel 2 using Tapatalk
