heat index is 105 here today, you must have gotten old, Dusty. I've made at least three trips from the air conditioned house to the air conditioned shop and it doesn't seem so bad out there.
Update?
So you're gonna bring that climate controlled shop down here so I might employ it ? Dusty
Sorry , been busy , hopefully by tomorrow evening . I tend to not form any preconceived ideas about what might be wrong in these situations , it keeps me from missing what the problem is . Just hoping at this point it isn't anything worse than an oil pump . Dusty
Too late now, Flat Track is on!!
^^^ Hopefully there will be an update tomorrow , thanks to everyone for the help and humor , if you can't laugh about this kind of thing it is time to put away the tools . Dusty
I hope you were able to work on the bike and had good luck today, Dusty
Did you find the trouble? sometimes when I look for a problem I cant find what it was but it fixes itself. Maybe a chunk of crud stuck in the relief valve and you dislodged it without seeing it. it might also be too hot to fool with it so I was curious if you were able to make any progress
You don't ride it enough, for one thing...
Wow, there is a wrench slower than I am.
